hello
I have 2 files: a movie.mkv file with an ac3 soundtrack with 2 channels (384kbps). Same movie but .avi format and ac3 5.1 soundtrack (448kbps).
I extract the 5.1 ac3 and muxed into the mkv file with avimux. Of course, the sound is delayed.
It is possible to sync the soundtrack with the movie (with avimux or something else?) If yes, how can I find the delay and what can I use to sync?
mkvmerge has a delay option. You can find the delay by opening the file in MPC HC and using the numpad + and - keys to adjust the audio during playback until it syncs. Then use mkvextractGUI to get all the bits of the file out to streams, then use mkvmerge to put it all back together again. You could also try AVI Demux, although I can't vouch for how well it works with MKV files (it does work pretty well for avi files)
Read my blog here.
AC3 Sync problem out of MKV file
By betão in forum Blu-ray RippingReplies: 7Last Post: 9th Jul 2010, 23:30 -
AC3 Audio Out Of Sync In MKV
By XiATH in forum Video ConversionReplies: 1Last Post: 24th Jan 2010, 12:09 -
MKV to MP4 for PS3 with dual-audio (2ch AAC + 6ch AC3)
By sexyclient in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th Dec 2008, 23:01 -
AC3 (5.1 or 2ch) to 2ch mp3
By shun in forum AudioReplies: 4Last Post: 11th Nov 2008, 08:50 -
sync ac3 from dvd to mkv hd video
By tertill in forum AudioReplies: 2Last Post: 1st Nov 2007, 16:46
