What the heck is a DX50 codec / decompressor? I've never seen this before... what else could I try to extract the video and save the file?
Why are you using a old version of Vdub ?. Is the source a ASF ?
Download the latest version 1.49 this might be your problem.
However the source AVI may have been made with a DX50 codec, who knows what people use to capture these days -
maybe the DX50 is the new DIVx 5.0 codec... I dont know... just suppose....
Fredİ -
I use an older VirtualDub cause I like .asf support, BUT THIS IS an .avi file... I'll try divx5 and a newer version of VIrtualDub too and see what happens... might try GraphEdit also
Hi
Ok found it. The DX50 is in fact the DivX5 codec, you get this error if you have installed over the top with an older codec, or simply don't have the divx5 codec in the first place.
If you have DivX 4.8 alpha on your system DivX 5 will replace it, if you install DivX 4.8 it will replace DivX 5-
thnx for the info it is the new divx 5
get it here::
http://download.com.com/3000-2194-10062728.html?part=divx
good luck
lr
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
How to convert dvd movies to DX50
By mbworldz in forum Video ConversionReplies: 8Last Post: 18th Jan 2010, 12:26 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
virtualdub compression for dx50?
By majax79 in forum EditingReplies: 4Last Post: 22nd Dec 2007, 21:51 -
I can't burn a MKV file using DX50 video to DVD
By traptedmind in forum Authoring (DVD)Replies: 0Last Post: 1st Jul 2007, 04:20
