Hi,
I am using ripbot 1.15 and 1.16 for quite a while and usually have no problems.
Then I encountered this error message:
"DirectShowSource: Couldn't open C:\temp\RipBot264temp\job1\video.mkv:
The system cannot find the file specified
(C:\temp\RipBot264temp\job1\getinfo.avs, line 2)"
This error message only appears, when I choose the TrueHD stream loading a mt2s form a BR stream folder.
As long as there is a non THD stream available I can live with this problem, but unfortunately this is not always the case.
I have tried ripbot 1.15 and 1.16 without success.
I would like to avoid converting the THD stream in another application (as TsMuxer), as this is quite time consuming detour.
Any ideas.....?
Mitch
