Ok, I have never had a problem with toolame prior to ripping Three Kings. I encoded several coasters for approximately 5 minutes and the final product came out great. (XSVCD - 3000 CBR, 224 audio).
So the last two nights before going to bed I have set TMPGenc 2.52plus (which hasn't failed me yet) and let the movie encode. But, both times toolame gives me some lame error about having to close the program.
Why would my practice runs be completely in sync and looking great, but when I try to encode the entire flik it quits? The wave is only 1.2gbs. I have encoded many films that had larger wave files.
I will check my default (toolame directory) again, but I have plenty of space on both my harddrives.
I just turned toolame off and the file encoded fine. I don't understand why it stopped on this movie.
Funny I can't tell a difference if toolame is on or off. Maybe TMPGenc audio encoder isn't as bad as I thought. -
i'm having the same problem but only recently. i've used toolame for 50-60 movies but until recently, it started crashing so i might have to revert to the internal encoder in tmpgenc
i didn't change anything at all.
Yeah I took it off as well.. I like it, but as you were saying early.. I really find it hard to hear the difference... Maybe its my crappy speakers
tks -
I agree, I have had the same problem with toolame-so I just use the TMPGEnc internal encoder and it work fine for my purposes.
crashes
By idolgolf in forum Newbie / General discussionsReplies: 3Last Post: 10th Mar 2010, 06:43 -
What to do when your PC crashes?
By aelfheah in forum ComputerReplies: 6Last Post: 29th Oct 2008, 12:27 -
Virtualdub crashes
By Kevlin in forum EditingReplies: 2Last Post: 18th Jan 2008, 23:01 -
2.5 crashes
By boggle in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 20th Jul 2007, 04:49 -
vdub_mp3_freeze crashes
By vertical in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jun 2007, 11:46
