I am trying to follow the below tutorial.
https://forum.videohelp.com/threads/273096-Blue-Ray-HD-DVD-TS-DVD-AVI-TO-H-246-using-MEGUI
after creating the test.avs script and opening it in Media Player classic and I am getting an error "Timeout waiting for graph to start."
This is what I have done so far. I used DVDfab to decrypt the BR disk and it created one .m2ts file. I left all audio options checked and unchecked all subs. I used BD50 so it would not compress.
I guess I have a couple of questions first.
1. Do I need to decrypt the .m2ts file first or can I use the file directly on the BR disk?
2. If so is there a better program to use other then DVDfab? (I'm using DVDfab because I purchased it.)
Now back to the error.
This is what the script looks like.
DirectShowSource("C:\BRaw\Invasion\BDMV\STREAM\000 00.m2ts",fps=23.976,audio=false)
I guess for starters I'm not sure that the fps is correct. I don't know if that would give me that error or not. How would I find out what the FPS are for the file I'm using?
I do know the path is set correctly. (I still remember quite a few things from the DOS days) lol.
I've become too lazy to get up and put a disk into a drive. I would rather spend hours trying to figure out how to rip a copy to my Media Pc. Go figure.
Thanks,
Rvn
Results 1 to 1 of 1
Should i use and avisynth script for Dv ?
By smartel in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2012, 08:29 -
AVISynth script error
By rvnwlf in forum Blu-ray RippingReplies: 1Last Post: 24th Aug 2010, 19:52 -
Opening Avisynth script on virtualDub - Error Message
By HugoBraule in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2010, 21:48 -
StaxRip AVIsynth script Error
By ic4andi in forum Video ConversionReplies: 0Last Post: 17th Nov 2008, 16:53 -
avisynth script
By magenta2007 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 25th Sep 2007, 11:29
