I knw this is probable lame but is there a way to convert RF video input to HDMI/DVI output?
I have a RF cable output that has to be connected to a HDMI/DVI input monitor Acer h235h. I am trying to find if there is a way to convert the RF signal to HDMI/DVI without the use of a TV tuner.
Can you suggest a low cost external USB TV tuner with HDMI output ? I have an analog cable signal that has to be transmitted on to a HD monitor [HDMI/DVI input]. Also, will the signal be any better if I transmit it via HDMI cable or will it be the same as the source?
You don't need HDMI at all if your source is analog cable; HDMI is for high definition video and your cable only gives you standard definition. Your monitor has HDMI, DVI and VGA ports, didn't you get the VGA cable to go with it? That's all you need to hook-up the tv tuner, using the other connectors won't give a better picture. If you don't have it, here's one. If you really must use DVI, then check this one, but at that price it's not going to make things any better. Alternately, you could use a gender changer on the tuner and plug this converter to your DVI cable.
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 17:20 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 20:32 -
DVI PC output to HDMI HD TV input?
By eros in forum DVB / IPTVReplies: 1Last Post: 26th Sep 2010, 02:38 -
Computer DVI output to TV DVI input
By superdud1400 in forum DVB / IPTVReplies: 12Last Post: 13th Jul 2008, 10:44 -
Trying to connect laptop dvi outut to HDMI Input
By vettesea in forum DVB / IPTVReplies: 16Last Post: 8th Jun 2008, 16:53
