Hey guys can anyone let me knwo how to rip movies to 350mb of 720p .
I use MEGUI and was gud in rippin movies to 350mb by using sources lyk 2CD and 1CD but whn i am tryin to use the source
lyk 720p i am unable to do it gud, the pixels r visible and only resizing it was fixing the problem a bit not totally.
Hw shld i do tht plz post a tutorial or let me know here guys, i ve been tryin to do it from past 1 week,
but couldnt, plz help me, i am dyin tryin nd tryin.
i wud be really grateful if anyone helps me out.
>>>Here is the way i do it using MEGUI<<<
AVS script creator > add my file > i keep the scan type progressive if its not >save
video section > avs is loaded > i config my codec (x264) > container as MKV > bitrate calculator(seting file size to 350mb) > enqueue
audio section > audio file is loaded > config my codec (nero AAC) >enqueue
and thn il START my jobs .
after chkin summ guides mainly this one (https://forum.videohelp.com/threads/2...46-using-MEGUI)
i ve edited my config, by increasing the reference frame rates and etc as mentioned in guides which retains the qualities,
but still no use its still the same after rippin.
PLZZZZZZZZZZ help me guys PLZZZZZZZZZZZZZ![]()
Results 1 to 1 of 1
MeGUI
By anirban in forum Video ConversionReplies: 4Last Post: 4th Dec 2008, 20:28 -
Help with MeGUI
By las7h0p3 in forum Video ConversionReplies: 6Last Post: 10th Nov 2008, 18:18 -
help using megui
By 3289275 in forum Video ConversionReplies: 2Last Post: 12th Oct 2008, 09:26 -
Changes in MeGUI
By Dschultz in forum Blu-ray RippingReplies: 3Last Post: 24th Sep 2008, 16:55 -
using megui
By cowboysroy31 in forum Newbie / General discussionsReplies: 2Last Post: 4th Jun 2007, 11:42
