Hey guys, I have a DVD in 4:3 format that I would like to make 16:9 but as you all know, cropping the entire movie would mean that in some scenes, heads etc are cut off, I was wondering if there's a way to crop the movie differently pretty much scene by scene or frame by frame so that you have the same resolution throughout the movie but the cropping is different in some places (like more on top or more on bottom in some scenes). Anyone know how to do this?
The few times I have had to do this, mainly to mix 4:3 and 16:9 material, I have used Vegas. This allows me to use Track Motion and keyframing to animate the location of the image within the 16:9 frame. Basically like a true Pan and Scan. If you can do a whole scene in a single movement it isn't so bad. if you have to do a lot of movement in the frame it can be quite time consuming, and rarely looks as good a real camera moves.
Read my blog here.
You can also do this with Virtualdub via a Widow Cropper plugin written by Khaver over at HV20.com: http://www.hv20.com/showpost.php?p=282380&postcount=7
Avidemux: The beginning frame is not a key frame. Please move the A marker
By devilcoelhodog in forum EditingReplies: 13Last Post: 8th Jun 2015, 12:38 -
Frame-By-Frame Restored James Bond Films Released
By Soopafresh in forum RestorationReplies: 9Last Post: 27th Apr 2012, 14:09 -
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53
