Hello, dear all.
I have one video file and I want to separate all its content ( video and sound), to syncronize between each other.There is a gap between audio and video. I want to match with each other.
How can I do it? Which programs can help me with that?
24.0 fps
AAC audio ( version 4) - LC - 44.1 KHz - 124 kbps - 2 channels
AVC1 - DSH ( high@ L4.0 - CABAC/1 ) / Type: DSH
Thanks.
devil (johner)
What container is the file using .avi, .mkv ??? is it dsh ?? need more info on the file stats.
Hello..
It's a "false" flv file.
Because, when I try demux it with FLVExtract it says it's not a genuine flv file.
So, I use mediainfo to get obtain all the information about the file... The data I put in previous post.
How can I see the "true" content container to work on it?
And yes, I think its a Satellite TV - HD Satellite Television - DISH extension file.
It says its a AVC content. MP4 file.
thanks.Last edited by devilcoelhodog; 11th Jun 2010 at 11:50.
Ok !!! :P
General
Complete name :
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 225 MiB
Duration : 8mn 43s
Overall bit rate : 3 605 Kbps
Encoded date : UTC 2010-06-07 09:26:54
Tagged date : UTC 2010-06-07 09:26:54
gsst : 0
gstd : 523771
gssd : BADC20AC7HH1276216944080902
gshh :
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 8mn 43s
Bit rate mode : Variable
Bit rate : 3 478 Kbps
Maximum bit rate : 21.5 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.070
Stream size : 200 MiB (96%)
Title : (C) 2007 Google Inc. v08.13.2007.
Tagged date : UTC 2010-06-07 09:26:56
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 8mn 43s
Bit rate : 124 Kbps
Maximum bit rate : 197 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 7.76 MiB (3%)
thanks. -
It looks like a standard .mp4 file use Yamb get it here https://www.videohelp.com/tools/YAMB to demux the streams. if you need help there are lots of guides below or post here again with what's going on.
Cannot display or convert video that uses AVC1 codec?
By peggypwr1 in forum Newbie / General discussionsReplies: 12Last Post: 4th May 2011, 04:19 -
Can't play or convert AVC1 / H.264 MOV files; help?
By jmills7 in forum Newbie / General discussionsReplies: 2Last Post: 28th Sep 2010, 21:01 -
AVC1 to MP4 playback speed too fast
By Cathedralcat in forum Newbie / General discussionsReplies: 3Last Post: 6th May 2010, 22:41 -
How to syncronize my subtitle?
By apache1990 in forum Authoring (DVD)Replies: 1Last Post: 7th Apr 2010, 04:18 -
No AVC1 avi playback in quicktime
By roper in forum MacReplies: 6Last Post: 11th Nov 2008, 13:42
