  1. Hi
    Im using AVIStreamWrite to create a video using a MJPG stream from a ethernet camera. I believe that I have to use aviSetFormat before I can use the above function. One of the arguments for the aviSetFormat function is a BITMAPINFOHEADER. I have tried entering the parameters manually but the video is just black. So is there a way of finding the BITMAPINFOHEADER of a image using a function call? Or does anyone know what parameters to use in the BITMAPINFOHEADER?
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    C#? or C/C++?
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
  4. Thank you for the reply. I will look through the code, hopefully it will help.
