This is the oddest problem and to say it's frustrating me would be an understatement. My Sony Vegas can no longer edit .Mov files captured by my Zi8 flipcam. It used to just fine. In fact, this exact copy of can open those same files just fine on my other computer which is identical to this one.
I tried uninstalling and reinstalling Vegas, but that's didn't help. I also tried restoring Windows to an earlier date, but that didn't help either!
Any ideas at all?
you can download imtooconverter.. this converter converts .mov files to .avi format with the exact same quality... it will be the same video,no lose of quality...trust me..
The problem will be one of the recent iTunes/Quicktime updates you have installed, not Vegas. It broke mov editing in a few places. Uninstall iTunes/Quaicktime, then try to find an older version.
As for imtoo - it re-encodes, so either you will get much bigger files, or you will get quality loss. You can't have both.Read my blog here.
Tiny Problem. MKV to MP4 and edit in Vegas.
By loosecontroi in forum EditingReplies: 18Last Post: 26th Apr 2012, 16:24 -
xdcam to .mov so I can edit with iMovie????
By boriega in forum Video ConversionReplies: 3Last Post: 15th Sep 2010, 01:39 -
I can't edit this mov quicktime file
By qisheng in forum EditingReplies: 19Last Post: 1st Dec 2009, 04:05 -
Can I edit HD MOV files with the newest Adobe Premiere or Sony Vegas?
By vatkat234 in forum EditingReplies: 3Last Post: 16th Nov 2009, 18:47 -
cannot edit wmv videos anymore (need a codec)
By SignedupGuest in forum EditingReplies: 6Last Post: 11th Feb 2008, 11:34
