can we fix the video bitrate in convertx2dvd? the version i have does not allow me to select the video bitrate. instead it allows me to select the output file size.suggestion please.
No, you cannot set the bitrate directly. If you want that level of control you have to move to something more complex than ConvertXtoDVD. Try AVStoDVD, which does give you control over the bitrate, if you need it.
I like ConvertXtoDVD, and I use it when I need a fast conversion with reasonable quality. However I find that the current version (4) woefully undersizes it's output compared to version 3. If I want quality, I use AVStoDVD instead.
That said, there are a few tweaks to the registry that you might be able to make, but you would have to spend some time in the VSO support forums to find out what they might be.Last edited by guns1inger; 11th Jun 2010 at 02:53.
Read my blog here.
I've found a lot of other problems with all releases of V4 I've tried (some mentioned in my Tools Section review here), that just don't seem to occur with V3. How so many conversions and burns can fail in 4, and then work fine in 3, belies any hardware issues and remains an annoying mystery.
Previously, I had found it more complex than I cared to deal with, but I'm getting ready to give AVStoDVD another try.When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
different output file size in convertx2dvd
By Iwan2learn in forum Authoring (DVD)Replies: 13Last Post: 13th May 2009, 03:29 -
ConvertX2DVD - menu issue
By urmum in forum Video ConversionReplies: 3Last Post: 31st Jan 2008, 07:59 -
ConvertX2DVD shutdown
By smalld in forum Newbie / General discussionsReplies: 2Last Post: 27th Nov 2007, 21:27 -
Need input with convertx2dvd and nero 7's menu builder
By MidnightMike in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2007, 14:48 -
What version of Convertx2dvd to use?
By aat666 in forum Video ConversionReplies: 8Last Post: 26th May 2007, 01:08
