Hi All,
I've spent a good few hours researching and trying code to do what I consider a simple task. I would like to have AviSynth read in an image sequence (which works fine). Then I would like it to display the last frame for 48 frames (2 seconds) whilst fading in some subtitles over the top where the fade in lasts for 24 frames. Then after the remaining 24 frames i would like a fade out for 24 frames of the whole scene. So a breakdown:
1. Display image sequence (48 frames)
2. Start display of last frame (48 frames) + start fadein of subtitles (24 frames)
3. no effect of scene for remaining 24 frames
4. Fadeout everything (24 frames)
Total clip length - 120 frames
As said, I can get the image sequence to play, this is fine. My trouble is trying to fadein the subtitles without causing the whole scene to go black and fadein. My code is below:
Many thanks,Code:Clip1=ImageSource("Stick\Animation%04d.jpg", 1, 48, 24).AddBorders(1000,140,248,140) Clip2=ImageSource("Stick\Animation0048.jpg", start = 48, end = 96, use_DevIL=true).AddBorders (1000,140,248,140).Subtitle("Test text").FadeIn(22) Clip3=ImageSource("Stick\Animation0048.jpg", start = 96, end = 116, use_DevIL=true).AddBorders (1000,140,248,140).Subtitle("Test text").FadeOut(22) Clip1+Clip2+Clip3
James
After another few hours of work, it's finally done! Happy days. I decided to go with the overlay option and used a sized transparent png as the 'frame' in which to place the text.
You can more easily fade in a subtitle using Dissolve.
Code:Clip1=ImageSource("Stick\Animation%04d.jpg", 1, 48, 24).AddBorders(1000,140,248,140) Clip2=Clip1.Trim(47,0).Loop(24) Clip3=Clip1.Trim(47,0).Loop(72).Subtitle("Test text").FadeOut0(24) Clip1+Dissolve(Clip2, Clip3, 24)
Avisynth script with subtitles - can i specify the size?
By Bully9 in forum SubtitleReplies: 11Last Post: 5th Jun 2013, 14:47 -
Using AVISynth to overlay PNG subtitles?
By csdesigns in forum SubtitleReplies: 8Last Post: 3rd Feb 2012, 11:36 -
Avisynth Script - Personal Subtitles hardcoding...
By elmuz in forum Newbie / General discussionsReplies: 0Last Post: 9th Nov 2010, 11:12 -
Cutting subtitles with Avisynth script...?
By Kalekulan in forum SubtitleReplies: 0Last Post: 8th Jun 2010, 14:34 -
AviSynth function to add SUP subtitles?
By MilesAhead in forum SubtitleReplies: 11Last Post: 3rd Feb 2010, 13:16
