I am trying to convert a mov file in TMPGEnc and the resulting video has the audio track but the video is a black screen.
Do I need a specific codec? TMPGEnc handled other mov files for me in the past...
Here is info on the source mov:
General
Complete name : E:\NIN project\Sacramento CAM1-1.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 7.33 GiB
Duration : 39mn 32s
Overall bit rate : 26.5 Mbps
Encoded date : UTC 2009-01-04 20:47:04
Tagged date : UTC 2009-01-04 21:02:50
Writing library : Apple QuickTime
Video
Format : hdv2
Codec ID : hdv2
Duration : 39mn 32s
Bit rate mode : Variable
Bit rate : 25.0 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate mode : Constant
Frame rate : 29.970 fps
Bits/(Pixel*Frame) : 0.536
Stream size : 6.90 GiB (94%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Duration : 39mn 32s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 434 MiB (6%)
Easiest would be to try convert with another converter, either directly to mpg or to avi and then to mpg with tmpgenc. Try xmedia recode, mpeg streamclip, mp4camto2avi.
Looks like mpeg2 (HDV) in mov container.
Here it is recommended to unpack the video stream and rename it to .m2v:
http://forum.doom9.org/showthread.php?p=1193205#post1193205
I think you can use YAMB GUI instead of pure mp4box. Then unpack audio (without 'raw' setting). Optionally you can use DGIndex/AviSynth for indexing m2v video stream.
Conversion from mpeg to mov: the sound is unsynchronized with video
By rikintosh in forum ffmpegX general discussionReplies: 4Last Post: 8th Feb 2012, 13:31 -
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
H.264 (MOV) to H.264 MPEG TS conversion
By svens in forum Video ConversionReplies: 0Last Post: 19th Feb 2009, 06:47 -
.mov to Mpeg 4 conversion issue
By Peplogic in forum Portable VideoReplies: 5Last Post: 18th Jun 2008, 18:56 -
Quicktime to Windows MOV-mpeg-4 conversion problems?
By Simone in forum ffmpegX general discussionReplies: 4Last Post: 16th Jun 2007, 06:50
