Hi guys,
Here's my dilemma -
All I want to do is Rip/Convert a DVD into a hi-res (or something half decent) .AVI file which can be used with both VirtualDub and Premiere CS4.
Happy for it to be DV-AVI (big file size) but my method which has worked for a while - rip with VOB2MPG, convert resultant .MPG file into DV-AVI with Adobe Media Encoder - has stopped behaving correctly with these new discs I've been getting, giving poor results (video stuttering, etc).
So I am looking for another tool to do the job.
Surely there’s something out there which does this very easily?
P.S. The DVD is non-copyright protected, and does not include a menu.
Current version of virtualdub with the mpeg-2 plugin to load the mpg or VOB files, and cedocida DV codec so you can save the results as DV avi.
Note : DV AVI is not HD/high resRead my blog here.
Thanks for that. Will give it a go.
Sorry, I should've clarified the DV AVI scenario. When I mean hi-res I really just mean high enough quality for the naked eye. DV-AVI is fine for this purpose. -
Personally, I would probably encode to Lagarith or Huffyuv from virtualdub, as these are lossless. DV compresses at a ratio of 5:1 and will introduce some degradation in quality.
Read my blog here.
By "stuttering," do you mean freeze-ups, or just odd-looking movements when the camera pans or there is movement in a scene? DV-AVI is bottom field first, while a lot of DVDs are top field first. You may just have a field mismatch.
Also, unless you need to do extensive editing, there is really no good reason to convert your DVD footage. -
As I said, it doesn't have to be super-high quality - DV-AVI is fine for what I need.
The stuttering occurs after running the .MPG file through Adobe Media Encoder - the vision never freezes up, but it seems to lose quality/pixellate/stutter the whole way through.
The reason I need to convert the DVDs is to do a lot of editing through VirtualDub/Premiere, so I definitely need a solid way of ripping the DVD and converting to a file type which will co-operate with both those programs.
DVP5990 and More Thumbdrive Grief
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Dec 2009, 10:05 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Needed: a beginner's guide to simple software
By hyphenate in forum Newbie / General discussionsReplies: 7Last Post: 29th Nov 2008, 14:20 -
[HELP] VOB Grief
By ZZiNo in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2008, 22:54 -
simple DVD software needed
By mike_L in forum Authoring (DVD)Replies: 10Last Post: 24th May 2007, 10:09
