Hi, I'm looking for someone to point me into the right direction for converting my Hauppage HD-PVR 1212 TS files to Xvid format. The programs I'm recording are in SD format (though recorded in TS in HD), so I'd like to compress them into standard 4:3 (512x368) format and be able to compress the file size as well (to save space). I've tried various converters but haven't found anything that works the way I want without different problems. Any help to point me in the right direction would be greatly appreciated. My mediainfo log is below:
General
ID/String : 0
CompleteName : C:\Documents and Settings\hd-pvrfile.ts
Format : MPEG-TS
FileSize/String : 1.17 GiB
Duration/String : 20mn 21s
OverallBitRate/String : 8246 Kbps
Video
ID/String : 4113 (0x1011)
MenuID/String : 1 (0x1)
Format : AVC
Format_Profile : Main@L4.0
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 4 frame2
Format_Settings_GOP : M=1, N=64
Duration/String : 20mn 16s
BitRate_Mode/String : VBR
BitRate/String : 7451 Kbps
BitRate_Maximum/String : 20.0 Mbps
Width/String : 1920 pixel3
Height/String : 1080 pixel3
DisplayAspectRatio/String : 16:9
FrameRate/String : 29.970 fps3
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bit3
ScanType/String : Interlaced
ScanOrder/String : TFF
Bits-(Pixel*Frame) : 0.120
StreamSize/String : 1.06 GiB (90%)
colour_primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
transfer_characteristics : BT.709-5, BT.1361
matrix_coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
ID/String : 4352 (0x1100)
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
BitRate_Mode/String : CBR
BitRate/String : 384 Kbps
Channel(s)/String : 2 channel2
ChannelPositions : Front: L R
SamplingRate/String : 48.0 KHz
Video_Delay/String : -68ms
StreamSize/String : 55.7 MiB (5%)
Read my blog here.
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15 -
AVI/Xvid MP3 to AVI/Xvid AC3
By MarquisdeOz in forum AudioReplies: 3Last Post: 10th Sep 2010, 06:59 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 20:05 -
winfast PVR -avi
By sg999 in forum Capturing and VCRReplies: 0Last Post: 12th Dec 2008, 13:13 -
convert 2cd Xvid to 1cd xvid Avi
By mehargags in forum Video ConversionReplies: 6Last Post: 14th Apr 2008, 11:55
