Hey Guys,
Sorry I am a ripping noob, but I could use some help. After I encode a movie, I no longer have true surround sound, even though setting suggest I would.
Here is my process...
I use tMuxer to rip a movie off the Blu-Ray. I rip the movie to a M2TS file and the audio to DTS. This file plays perfectly, I get surround sound (my reciever correctly registers as reciving DTS audio) but the file is HUGE! So I try to reduce the size with...
Xilisoft Video COnverter Ultimate 6.
My settings are as follows...
Video Codec: H.264/MPEG-4 AVC
Video Size: (hd 1080)
Bitrate: 12000k
FramerateL 29.97fps
Level40
Audio Codec: MPED-4 AAC (this is the only choice I get)
Sample Rate: 48000
Bitrate: 320k
Channels: 5.1
After encoding the movie, my receiver registers the audio as stereo!
Any help would be appreciated!
Thanks!
Check the file with MediaInfo and see if it's just stereo. I usually convert to 640Kbps AC3 6 channel as it's more universal.
I've never used Xilosoft, so no help there. I use RipBot and usually convert to MKV, but you can convert to AVCHD if you want Blu-ray compatibility.
You can also use BD Rebuilder.
What's your final format? A AVCHD, or a Blu-ray disc, DVD for a set top player, or just hard drive playback? What size are you going for?
And welcome to our forums.
Thanks for the welcome!
The final format comes out as .mp4. I was told the codec I should be using is H.264, and that setting gives me .mp4 when it is done. I want pretty high quality rips, so I had the video at 8.39GBs and it looked great for me.
I am NOT putting it back on a disc at any point, it is for my media center computer, so it is just living on a HDD.
So I use that MediaInfo program and it says I have 319Kbps, 48kHz, 6 Channels, AAC (Version 4) (LC)
I am guessing maybe my receiver can't understand this format?
So I guess my next question is, is there a way for my to take the uncompressed original DTS Audio from the initial rip from tMuxer and mix it with the Xilisoft encoded video easily?
EDIT: I have Ripbot, but when i tried to use it, the file was huge and came out squished!
So I tried a different program, maybe I will return to using it if I cant figure this out...
Your media centre is probably sending 2 channel PCM to your receiver because it can't handle AAC audio. My PS3 has to do the same.
MP4 can handle AC-3 audio although this is a relatively recent addition and no all encoders can do it, and not all player recognize it. You could try a different container that does handle AC-3 (or even the original DTS) audio - m2ts is one option. All you have to do is recompress the video to get the size down.Read my blog here.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
Lg ht 355sd surround sound
By byrnech in forum DVD & Blu-ray PlayersReplies: 5Last Post: 27th Oct 2011, 06:08 -
DTS encoding ( Stereo to surround ) ?
By 3thman in forum AudioReplies: 6Last Post: 6th Feb 2010, 07:06 -
Encoding AC3 to WMA Without losing 5.1 Surround (please help)
By RabidSmurf in forum Video ConversionReplies: 4Last Post: 2nd Mar 2009, 15:03 -
Virtual Surround Sound
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 3Last Post: 28th Dec 2008, 12:17
