So far I've used DVD+R DLs from Memorex and Fuji, and they sometimes work. After a little bit of internet research I discovered that this machine is not entirely compatible with those types of discs. No biggie, I'll just get some DVD-R DLs which this machine is compatible with. I found a pack of RiDATA DVD-R DLs which are read flawlessly by the machine and record fine until the machine switches layers. After the machine switches layers on the disc an error message appears and the machine stops recording and opens the disc tray. It appears that the only other manufactures of DVD-R DLs are Verbatim and JVC.
Have any of you out there had any similar problems? Could any of you offer any advise? Are there problems with Verbatim and JVC discs too?
Could this lack of Double Layer support be Panasonic's way of wanting consumers to use DVD-RAM discs instead?
Results 1 to 14 of 14
Verbatim DL are the best and most reliable to use. Don't even bother trying any others.
Also, buy your Verbatim online, not in the stores (actually, SAM's has the best deals i've seen).
Trust me, the brands on Micro Center i would not touch like Ritek or even Sony. My ceiling is around $1.30 per disc for Verbatim. Try newegg.com or supermediastore.com for these. Sometimes Best Buy has them on sale for $29.99 for 20, but even that is still a little high. Every one i have bought online i've had no problems. Usually they are 4x or 2.4x.
Micro Center would be fine too. It's just that online is usually cheaper and if you can find a Sams with Verb DLs left they will probably be $39.95 for 50 which is a great deal. Most Sams around here are sold out of the Verbs(which previously sold for $59.95 which was a decent deal) and now Sams stocks only Memorex
If at Micro Center don't be tempted by the cheap Windata DL media. I tried a spindle in my Panasonics and had awful luck, Verbs work about as good as DL media gets and I'd suggest the 2.4x over the 8x if you have a choice. -
My research for Verbatim DVD-R DLs (three-pack):
Micro Center: $10.99
Amazon.com: $11.86 (through Shoplet)
Newegg.com: $13.99
I was surprised to see Newegg as the most expensive. Maybe there will be a sale soon.
So can I return the crappy RiDATA discs or not? I took the packaging off and used a few of them. I'm pretty sure I kept the receipt, either in my wallet or in my car. Unfortunately I'm not too familiar with Micro Center's return policies because I've never had to return anything! -
After reading the specs on your particular Panasonic model, I don't think that unit records to DL discs. Check your owner's manual.
This link says it does: https://www.videohelp.com/dvdrecorders/panasonic-dmr-ez48v/2347
But some of the dealer links don't list DL. That's why you need to check your manual.
EDIT: Never mind. Consumer reports says it does. http://www.consumerreports.org/cro/electronics-computers/audio-video/blu-ray-and-dvd-p...v-99020931.htm
Yeah. Buy Verbatims, I guess. But I'm not real sure about -R DLS. The +Rs are reliable. -
Newegg is rarely the cheapest option on anything -- it's just a popular one.
Sort of like Walmart, Dollar Store or Big Lots. Not everything is the best price at those places.
CR is hardly the watchdog for DVD recorders. Lots of bad info in there in the past.
Either use Verbatim DVD+R DL (best prices usually at Amazon, no tax and free shipping) or don't use DL media.Want my help? Ask here! (not via PM!)
Also, if you go to the store to pick up some Verbatim +Rs, make sure it says "Made in Singapore" on the packaging. If it says "Made in India" or anything other than Singapore, DO NOT BUY THEM.
That's just a myth. The discs from India are made the same, with the same materials and oversight, as the ones from Singapore. The 2.4x come from Singapore, the 8x come from India.
Verbatim has confirmed this more times than I can count.Want my help? Ask here! (not via PM!)
I'm not sure that those numbers are entirely correct. This is what I have found from my personal buys.
1) If I buy the white ink jet printable DataLifePlus DVD+R DL discs, they are ONLY made in Singapore. They are at 2.4x speed.
2) However, the lower rated non-printable silver discs tend to be made in India. This includes the 2.4x discs. They MAY be made in Singapore, but mostly they are made in India.
3) I have not seen the 8x-10x discs made anywhere but Singapore. If India made those discs at one time, they may not do so now.
4) Those 2x-6x discs usually are made in India.
5) I don't personally put a lot of stock in it, but I did do a comparison of burning the same thing to India and Singapore made DVD+R DL discs by Verbatim on the same burner at the same speed and checked them with Nero's Disc Tool. The made in India discs did show as being somewhat more prone to errors.
The slower and cheaper the media, the more likely it is made in India. It seems to me that Verbatim thinks that Singapore makes better discs given that the faster and more expensive discs are made there. -
Singapore is just their own facility, there's nothing really special about it in terms of quality -- all MCC media is made to their specs and should therefore be considered good products.
Digital tuning on Panasonic DMR-EZ48V
By knahs in forum Newbie / General discussionsReplies: 5Last Post: 16th Mar 2012, 14:27 -
Question about USB recording on the Panasonic DMR-EZ48V
By afroconnection in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Sep 2010, 09:06 -
VHS to DVD Help (panasonic dmr-ez48v)
By BrianJ844 in forum Newbie / General discussionsReplies: 14Last Post: 21st Jul 2010, 19:03 -
Burning Double Layer Disc
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2009, 08:22 -
PANASONIC DMR-EZ48V tuner advance problems
By PLEIADES in forum DVD & Blu-ray RecordersReplies: 5Last Post: 12th Jul 2009, 17:32
