I have a large number of videos I encoded to MP4 a few years back. (These were video clips I took with my camera). I've now found that while the videos play perfectly fine using Directshow (Windows Media Player), VLC, and MPC, they are choppy and distorted when using the quicktime player. (I use Windows 7 x64 with the Shark007 Codec pack)
Yes, I know the simple answer is 'don't use quicktime player' but my issue is I organize all my personal photos and videos using Picasa, and Picasa seems to insist on rendering MP4 files using quicktime, not directshow. So right now I'm out of luck if I want to view the video in Picasa.
I'm wondering if there is any way to fix this short of re-encoding the videos. (eg, would re-muxing them help?) I have some newer videos I encoded to MP4 (using Handbrake) and these play fine in Quicktime/Picasa, so I wonder if the older videos are slightly out of spec?
I also tested the file on my wife's laptop as well as my son's macbook and each had the same quicktime problem.
Here's the Mediainfo information for one of the files in question. Is there anything here that looks off?
General
Complete name : C:\Users\larry\Pictures\2007\summer 2007 trip\MVI_0736.mp4
Format : MPEG-4
Format profile : Nero Digital Standard Profile
Codec ID : ndss
File size : 19.8 MiB
Duration : 47s 554ms
Overall bit rate : 3 489 Kbps
Encoded date : UTC 2007-09-15 01:41:03
Tagged date : UTC 2007-09-15 01:42:14
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 47s 500ms
Bit rate mode : Variable
Bit rate : 3 405 Kbps
Maximum bit rate : 4 850 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.369
Stream size : 19.3 MiB (97%)
Writing library : em4v 4.1.6.5
Language : English
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Bit rate : 79.8 Kbps
Maximum bit rate : 86.2 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 463 KiB (2%)
Language : English
Results 1 to 12 of 12
Quicktime doesn't use any of Windows' video acceleration features so it's a very poor media player. I don't think its h.264 decoder is even multihthreaded. But a 640x480 MPEG 4 part 2 (Xvid/Divx) MP4 file shouldn't have any problems unless you have a 100 MHz Pentium 1 processor.
Here's the original file if someone would be so kind as to try it on their system:
http://drop.io/bbp1oha/asset/mvi-0736-mp4 -
There's something a little odd about that file. I was able to play it with MPCHC (internal MP4 splitter and Divx decoder) but it was a little jerky -- like it was skipping every other frame. KMPlayer did this too. VLC played it smoothly. After remuxing into na MKV container all three players played it smoothly.
I seem to be having problems with some of these remuxing programs. YAMB doesn't seem to create valid files, and mymp4boxgui is crashing. I also tried megui, which seemed to sucessfully remux it, but the new file still played choppy in quicktime.
@jababo, what tool did you use to remux to MKV? -
Guys, I think you've put me on the path to a solution. While there doesn't seem to be a fix for the quicktime problem, based on your suggestions I have an alternative solution.
If I remux to MKV I can completely avoid quicktime as Picasa uses directshow to render MKV files (which play fine)
'MP4 has no usable track' yet plays in VLC Media Player
By JuliaR in forum Newbie / General discussionsReplies: 6Last Post: 10th Mar 2012, 17:57 -
Mac OS X Lion QuickTime Player Choppy Audio
By zBernie in forum Software PlayingReplies: 2Last Post: 17th Feb 2012, 20:05 -
Recorder FLV converted to MP4 plays no video in QuickTime
By ballenato in forum Video ConversionReplies: 6Last Post: 25th Nov 2011, 09:17 -
DVD Player that plays Divx (.avi) and (.mp4) files ?
By keith knip in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Oct 2011, 14:12 -
MP4 player plays only MTV - HELP
By Lensmeister in forum Video ConversionReplies: 2Last Post: 25th Dec 2008, 17:35
