Results 31 to 33 of 33
Of course. I even use the "EZ Mode Picker" - Write Files/Folder To A Disc.
ImgBurn reads and instantly knows how this "folder" needs to be burned(as DVD VIDEO) and pops up
a screen to show you the possible layer break positions(if you are burning a DL disc).
You have to understand....ImgBurn does NOT create a layer break position, it lists the choices and rates them.
If you create a giant DL DVD with no chapter markers between scenes, you have just limited ImgBurn's choices
for a smooth layer break dramatically. Now ImgBurn has only the division between the VOB files...not good.
Not impossible, but not good.
When you rip a large "movie only" that still requires a DL disc....unless you changed some serious setting in the ripper, you still have the chapter markers intact. Messing with the ripper settings is unnecessary. Obsession with creating ISO images "so you can use ImgBurn" is unnecessary. ImgBurn EASILY handles VIDEO_TS folders as well. You have received tons and tons of "extra work" and "bad advise" in this thread....none of which came from me....
Did you know ImgBurn can also create Audio CDs from your WAV files AND MP3 files?
I'm telling you....ImgBurn is MUCH MUCH MUCH smarter than you think it is. -
Did you know that when you select "Write Files/Folder To A Disc."you ARE in Build mode?
Check it out:
Use the "EZ Mode Picker" and select "Write Files/Folder To A Disc".
Then, click on the "Mode" menu item. Notice that "Build" has the check by it.
Write mode REQUIRES an ISO file.
Build mode uses a VIDEO_TS folder (with the VOB files in it).
So, when you said, "I never use Build mode"... that meant you use Write mode and thus ISO files.
But, as you have pointed out, you actually are using Build mode.
And, I agree now that I've tried it ImgBurn IS the best tool for burning.
AVI (DivX) layer break issue with IMGburn on DL DVD's
By masherdude in forum Newbie / General discussionsReplies: 4Last Post: 31st Oct 2010, 12:22 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
How to DVDshrink 7GB of video to DL DVD that handle layer break ?
By SingSing in forum Newbie / General discussionsReplies: 3Last Post: 25th Apr 2010, 15:53 -
Burning problem with layer break?
By darrenp76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Sep 2009, 12:08 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 12:27
