Results 1 to 11 of 11
  1. I have converted the .ts file to a vob file (The conversion keeps the ratio the same) and then used ConvertX to DVD program to transfer to DVD. I then play it on the DVD and the image is stretched!?
    The program states that it should be set at 'Letterbox': Recommended: video reduced (no image data lost, black bars maybe added)
    Its a great program and I believe the best in its area, the other free alternative DVDflick does the same. How do you over come the problem? What is the best resizing filters and other factors should I take into account? Ahh I wish I could just press a button and it will all done, it was so simple with a video recorder.
    Oct 2007
    convertxtodvd is converting the VOB video a second time. If you have a DVD compliant VOB file then use an authoring app like dvdstyler or gui for dvd author to make it into a DVD without needlessly converting a second time.
  3. OK, what is the best method of converting a .ts file from my Foxsat-hdr and transfering it to DVD? I use Aimersoft video converter ultimate or I can use Total Video converter, but I prefer the Aimersoft. All I am trying to do is put my TV programs onto a disk and as usual things are never simple, in fact they are just too complex for my brain to understand. Especially as I live on a daily dose of morphine, things don't sink in. Looking forward to your reply, Thanks
    Apr 2004
    Miskatonic U
    If you have ConvertXtoDVD, use that to create the DVD from the source files. Or try AVStoDVD.
    Read my blog here.
  5. The problem is it is a .ts file and I needed it trimmed to get rid of all the TV rubbish. I suppose its knit-picking but I like to ensure I don't have to watch the rubbish, just what I want. Any ideas where to go from here to get it right? Also is it worth putting the aspect ratio to 4.9 or 16.9 as setting it to 16.9 makes it stretched or will that resolve itself?
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Start with a mediainfo tree view of the file to see what it really is. Maybe post a screen shot. And stay away from crap like Aimersoft, which is not doing you any favours.
    Read my blog here.
  7. Ok, here is the info from the software. The opera has too much info on the start and at the end. I don't have a Blue-ray just a DVD so its irrelevant to talk about blue-ray. Thanks for your help although I am not sure why this helps in trimming the end of programs etc and anything else that is added on.
    General
    Complete name : C:\Users\Tony\Videos\USB Foxsat\Aida_20100604_1929.ts
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 3.96 GiB
    Duration : 2h 25mn
    Overall bit rate : 3 888 Kbps
    Video
    Menu ID : 6316 (0x18AC)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Duration : 2h 25mn
    Bit rate mode : Variable
    Bit rate : 3 209 Kbps
    Nominal bit rate : 15.0 Mbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.310
    Stream size : 3.27 GiB (83%)
    Audio #1
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Duration : 2h 25mn
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Video delay : -264ms
    Stream size : 267 MiB (7%)
    Language : English
    Audio #2
    Format : MPEG Audio
    Duration : 2h 25mn
    Bit rate : 256 Kbps
    Video delay : -216ms
    Language : nar
    Text
    Format : DVB Subtitles
    Language : English
    Menu
    Duration : 2h 25mn
    List : 5300 (0x14B4) (MPEG Video) / 5301 (0x14B5) (MPEG Audio, English) / 5302 (0x14B6) (MPEG Audio, nar) / 5304 (0x14B8) (DVB Subtitles, English)
    Language : / English / nar / English
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    It appears to be bog standard 16:9 PAL mpeg-2 DVB material. Best options for trimming with minimal damage would be VideoRedo or Womble Mpeg Video Wizard. Neither are free, but both are well worth the modest investment if you are going to do this more than once. They will let you edit mpeg-2 video without the need to re-encode it, and they won't screw up the aspect ratio. Both also have DVD output capabilities, although VideoRedo doesn't do much in the way of menus
    Read my blog here.
  9. Thanks, I have Womble, did try Videoredo but it just hung there on installation. I took down all the security and other bits but it can't like a Win7 64bit system. The problem is always when its put onto disk and thats when I have to fiddle about with the width aspect of the remote controls to fill the screen and its a dam nuisance. Bring back video simplicity!! You record and file the tape, just wish it was the DVD disk. They call it progress.HUH!!
    As I still really have no idea how the whole things ticks and still have a problem I will still get frustrated as it beyond my grasp as it seems for many, many others.
    Thanks you kindly for your assistance
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    It is a simple video, so I can't understand why you are having any issues with it at all. Try Xvid4PSP. Open the source file, set the output to MPG and the video and audio to Copy. This should give you an mpg file that you can open in Womble. Once you have the mpg file, open it in Mediainfo and again check to make sure the aspect ratio is still set to 16:9. If not, use DVD Patcher to set the flag, or set it when you author your disc after editing in Womble.
    Read my blog here.
  11. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    The mediainfo log makes it appear to be pretty much the same as digital tv here in New South Wales Oz... What I do with these files is demux it through ProjectX (see settings in my signature) ProjectX also gets rid of a number of transmission errors. Then use Womble to remux and do any further tidying up and export a DVD compliant MPEG2 file. You can aslo edit in ProjectX if you wish, especially if there are subtitles and you want to preserve sync. Import the MPEG2 files into ConvertXtoDVD and if the settings are correct you should have a DVD with the correct aspect ratio. According to mediainfo it is 16:9 so when it was transmitted was it widescreen? DO you view on a 16:9 panel or 4:3?
