I have a system running winXP Pro, and I'm useing A Matrox G400 with a Rainbow runner G-series capture card. I didn't realize till recently that the Video tools for neither Win 2ooo or Win ME work with card for capture (the last time I used the card for capture was when I had WinMe installed) Lately I've been caputering off a DV camera w/ firewire. But now i need to pull of a VCR. If I use the Vidtools for Either Win2K or WinME I get cannot find device or it's being used by another blah, blah, blah. Anyway if I pull out the drivers disk that cam with my RRG I can install the Vidtools but not the driver (they're win95/98 only) but I can view the video playing on the VCR, but I still can't capture it, I get the "drivers may need to be reinstalled" story. I was wondering if there is a 3rd party Video program that can access the Hardware itself like Ulead or Adobe, I don't need to capture in Mjpeg, AVI is fine with me. Or should I Have (3) Hard drives (1) for WinXp & My programs, (1) small one for win98 & The Matrox Vidtools and (1) large one for a Scratch disk. I spent $300 to get the 2 cards and hate to think I have to scrap them both just to get another one.![]()
Hi,
First off check the Matrox site for XP drivers, might be a solution. The G400 is not an old card so I suspect it should be supported.
Secondly, if no updated drivers, then do exactly what you suggested, create a dual boot system, have your Rainbow runner on the partition you can get drivers for, and save your captured video to a dedicated drive that can be seen by both XP and the alternate system.
Ignore any question marks in XP reference the rainbow runner.TOMMO -
Checking for updated Xp drivers was the first thing I did, they stop at WinME and 2K.
As for "?" in Device manager, I was not blessed by those, according to Win XP The G400 is the only Video card in the computer. -
Hi..
I've been through the same thing, and I went with the multi-boot option. I have Win98 running on one drive and dedicated it only to video editing. Then I have XP for everything else.
I really like the RRG card and I'd rather swicth back and forth between 98 and XP rather than replace it.
D.
I don't get why Blade Runner is special - ok movie but a classic?
By yoda313 in forum Off topicReplies: 24Last Post: 28th Feb 2011, 17:36 -
Putting the Mystique/Rainbow Runner out to pasture...
By logic7 in forum Capturing and VCRReplies: 2Last Post: 7th Dec 2009, 16:45 -
Rainbow effect
By rism47 in forum Authoring (DVD)Replies: 7Last Post: 31st Jan 2009, 16:47 -
Laserdisc: Blade Runner
By vhelp in forum Off topicReplies: 11Last Post: 2nd Aug 2008, 00:19 -
Blade Runner Briefcase Dangerous Days (Disc 2) menu problems after shrink
By jrshull in forum DVD RippingReplies: 9Last Post: 21st Mar 2008, 13:49
