I've just got a HD Satellite receiver that records in .ts
I want to convert videos to this format so I can watch them on the TV instead of laptop.
So far the only tool I've found that does it well (and it does do it perfectly) is RER Video Converter.
I was very close to purchasing it as I can't find a free program to do it but then FF started telling me that the site is dodgy.
Anyone know if it is, and if so then any ideas for other converters?
Super(c) does it but the quality is terrible and takes ages.
RER one is very good quality and quick, but free version only does first 20% of vid.
Cheers!
I have a Foxsat -HDR and all I do is poke my USB pendrive in the front of the recorder download the file (except you can't load HD as it won't allow anything bigger than 4GB file) and transfer it to my computer. VLC free media player plays .ts files. To convert I use Aimersoft video converter Ultimate or I use the Total Video Converter, which emphasises it capability to convert these files
http://www.effectmatrix.com/
I can also convert these to DVD by using DVDFlick (free) or better ConvetXtoDVD4. But there is my question which I shall ask on another thread. Hope it helps, its a start for you anyway and I am sure my small piece is a fraction to what others here will tell you -
Ah you might find this handy if you have the Foxsat
http://www.hummy.org.uk/forums/showthread.php?t=6920
Its a piece of software that converts to .ts files so you can play items on your freesat HD hardware -
Trying AV2HDR now.
I need to convert AVI (or anything) to .ts
VLC does not play the .ts files
The RER converter was very fast with great results... Just a shame the site seems to be dodgy.
Will try some of those recommended programs.
Thanks very much, I'll keep you posted on my progress. -
Problems with flv file
By kurmaza in forum Video Streaming DownloadingReplies: 3Last Post: 7th Dec 2010, 12:32 -
Help Please Vob file problems
By Kwalsh11 in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2010, 02:41 -
problems going from quicktime mac file to usable pc file
By pjcom in forum Video ConversionReplies: 11Last Post: 19th Apr 2010, 13:49 -
Problems converting a file
By Mr_Del in forum SVCD2DVD & VOB2MPGReplies: 19Last Post: 7th Dec 2007, 10:39 -
AVI file problems.
By wicked_pix in forum Newbie / General discussionsReplies: 9Last Post: 5th Dec 2007, 10:27
