Can you determine which item defaults as the first highlighted item on a menu?
If so, how?
Thanks!
"It's more like a big ball of wibbly-wobbly, timey-wimey... stuff"
The 10th Doctor from "Blink" -
You can only edit it afterwards in DVDRemake or PGCEdit. TAW uses register 11 for setting highlighted button number before going to a menu PGC. The default selected button # is usually (by TAW's internal template) defined in the last line of pre-commands in a PGC marked as 'title menu' in VMG or 'root menu' in a VTS with track menu. The numbers like 1024, 2048, 3072.. etc. correspond to buttons 1, 2, 3.. Easier editing can be done by forcing particular button highlight on menu start-up but this way you can't use control of highlighting by current chapter# (if called from playback) etc.
TMPGEnc Authoring Works 4 Menu Help Needed
By VOYAGER2009 in forum Video ConversionReplies: 1Last Post: 15th Apr 2011, 12:37 -
TmpGenc Authoring Works 4 - Motion Menu Question
By blazin-j in forum Authoring (Blu-ray)Replies: 3Last Post: 18th Oct 2010, 10:00 -
TMPGENc Authoring Works 4 - motion menu no audio
By mobie29 in forum Authoring (Blu-ray)Replies: 3Last Post: 16th Jul 2010, 16:32 -
TMPGEnc Authoring Works 4 - Menu help
By NotSoEasy in forum Authoring (DVD)Replies: 9Last Post: 1st Mar 2010, 02:24 -
TMPGEnc Authoring Works 4 Single Menu
By Sakuya in forum Authoring (DVD)Replies: 3Last Post: 22nd Dec 2009, 02:04
