  1. I have been having pretty good sucess copying blu-ray movies with anydvd, bd-rebuilder and imgburn up until now. I have been able to copy only one out of the last 6 movies and that one was Rocky. I select the "movie only" version. Everything goes according to plan from the ripping, rebuilding and burning stages without any errors. But, when the burning is done and I play the bd-re disc (25) in my player all I get is "cannot read disc, please check disc." I have the lasted versions of anydvd, bd-rb and imgburn. How can I check if the movie was ripped in the first place to my hard drive or if imgburn isn't burning it. All the blu-ray discs that I used where brand new Verbatim brand. Some of the movies where new releases and some were older movies converted to Blu-ray. I have no problem copying dvd movies with dvd shrink. Thank you for any reply.
    Does your old burned bdrs that worked before still work fine?
    Does the bdr work on your computer with a software bluray player?
  3. I haven't tried re-copying the bd-re disc that worked before. I was afraid of losing the movie. I was also successful burning on 8 out of 10 verbatim bd-r discs. The 2 that didn't burn also gave me the same error "can't read disc, check disc." I have been very successful with dvd movies using dvdshrink, No errors so far. Thank you very much for your reply. I just tried playing 2 movies on my computer that I was able to copy before (1 on a bd-r and 1 on a bd-re) using windows media player and it told me that the discs were empty. They play on my blu-ray player though.
