Results 1 to 17 of 17
  1. i took this video of my daughter dancing in my friends basement and on my computer with the original file i can see pretty good but its still dark. when i posted it on my youtube it was unwatchable. is there any way to make it brighter from the original? i dont know much about working with videos so any help is very much appreciated!!!
    Apr 2004
    Miskatonic U
    The best method may depend on the source of the video. Post a mediainfo tree view of the file so we can see what it is.
    Two of the simpler would be virtualdub or AVI Demux, which will let you play with the brightness and contrast. Note that video shot in low light is usually very noisy, and brightening it will make the noise more visible. It will be a balancing act between making it bright enough, but not too bright that the noise makes it unwatchable.
    Read my blog here.
  3. Member fitch.j's Avatar
    May 2009
    Whats the original footage info?
    Have you got a link to what youtube did to it?
    Maybe a sample upload?
  4. Just about every video editor has brightness/contrast filters. But dark video usually becomes grainy when you brighten it up. If it's a highly compressed format you will end up with a lot of posterization artifacts too.
  5. Member fitch.j's Avatar
    May 2009
    There are lots of other possibilities besides bad brightness and contrast control included in most software. In order to determine whats best though we just need more info on the clip. Simply pushing your brightness and contrast is a sure way to make it look bad.
  6. the video is a quicktime format and here is the link to the youtube one http://www.youtube.com/watch?v=dao9HiEMkPE the original video is 32 mb so it wont upload im not sure how to do a sample upload or the mediainfo tree thing i used the youtube downloader to change it to window media audio/video file and its small but again darker than the original
  7. ok i downloaded and kinda figured out the tree thing but how do i get it to here... when i try to export it and then open it it comes up all kinds of weird looking... and it wont let me copy paste it
  8. in mediainfo (view=>text) , then you can copy and paste
    for your native video sample, you can use a free hosting site e.g. mediafire.com, sendspace.com
  9. ok here you go
    General
    Complete name : L:\picture drive\2008\2008-11-06\100_1744.mov
    Format : QuickTime
    Format/Info : Original Apple specifications
    File size : 32.9 MiB
    Duration : 2mn 1s
    Overall bit rate : 2 275 Kbps
    Movie name/More : EASTMAN KODAK COMPANY KODAK M753 ZOOM DIGITAL CAMERA
    Encoded date : UTC 2008-11-01 20:16:53
    Tagged date : UTC 2008-11-01 20:16:53
    Origin : Digital Camera
    Video
    Format : M-JPEG
    Codec ID : jpeg
    Duration : 2mn 1s
    Bit rate mode : Variable
    Bit rate : 2 181 Kbps
    Width : 320 pixels
    Height : 240 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 30.038 fps
    Bits/(Pixel*Frame) : 0.945
    Stream size : 31.5 MiB (96%)
    Language : English
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Unsigned
    Codec ID : raw
    Duration : 2mn 1s
    Bit rate mode : Constant
    Bit rate : 88.2 Kbps
    Channel(s) : 1 channel
    Sampling rate : 11.025 KHz
    Bit depth : 8 bits
    Stream size : 1.27 MiB (4%)
    Language : English
  10. i used mediafire to upload it so here it is! anything someone could do to help would be awesome
    http://www.mediafire.com/?hat3thzwnrn
  11. Before and after some quick brightness and levels adjustments in VirtualDub:
    Some deblocking, noise reduction, white balance, and saturation adjustments are called for too.
  12. Member fitch.j's Avatar
    May 2009
    Your main issue here is how badly underexposed it was in the first place. There is really very little that can be done, and even then your instantly introduing artifacts. You can see here your problem in the histograms, The second is an example of just pumping the brightness a little, you see how it just spreads the bars. With more work you could make it look better thats for sure. But with a source that bad it'll never look good.
  13. all of those are better than i ever expected!!! is there any way to make the whole thing like that and send it back to me?? thanks so
    much for all the help!
  14. Originally Posted by liltroysgrl View Post
    Xvid MP3 AVI:
    http://www.mediafire.com/?xxm41rtktm1
  15. jagabo- i downloaded the file from the link but it wont play on quicktime and on windows media player it is only sound... not sure what went
    wrong lol i redownloaded it and same thing!
  16. You probably need the Xvid codec. WMP should play the file after you install it.
  17. omg thanks so much that is awesome... i so appreciate all the help... you guys are AMAZING!!!
