hi
I never had subtitle problems in my local language until Avatar, every single .srt file causes squares (1-2) in each line, I tried many subtitles, all the same results.
I have another new film, I got subtitle for it from same website and it worked from first time with no subtitle problems.
I tried changing the encoding in subtitleEdit to all the available one and nothing fixed the problem.
why is this happening to avatar alone ?
How can I know the exact encoding used in some subtitle?
It sounds like the .srt may be unicode. Try opening the .srt in Notepad, then do Save As and choose Ansi encoding. If that doesn't work try the others like UTF8 and see if any look clean.
http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs.
Resolved: Use Subtitle to Create Border on DVD Without Re-encoding
By sambat in forum SubtitleReplies: 6Last Post: 26th Feb 2012, 07:07 -
subtitle issue when re-encoding..
By tsh in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2011, 00:26 -
mkv subtitle encoding problems (Yes i searched and tried out everything)
By -Tom- in forum Newbie / General discussionsReplies: 5Last Post: 1st Sep 2009, 17:16 -
Encoding Subtitle Problem 2 sets appear on screen ??
By tsam19 in forum SubtitleReplies: 24Last Post: 16th Mar 2009, 16:52 -
Encoding a DivX with bigger subtitle.
By Ashernor in forum ffmpegX general discussionReplies: 6Last Post: 5th Jan 2008, 16:29
