Hello.
I have a Canon FS200.
When I put the video on my computer, I can read them very well on Window Media Player.
When I try to edit them using Window Movie Maker or Adobe Premier or the Software included with the camera: there is no sound!
I need help before I return the camera!
Thanks,
Gautier
The canon fs200 records in ac3 and many editors doesn't support that.
If you have adobe encore you can try
"Just copy "ad2ac3dec.dll" from Adobe Encore root folder, to Premiere root folder and it's done!!!"
https://forum.videohelp.com/threads/240594-Importing-AC3-into-Premiere-Pro?p=1696110&vi...=1#post1696110 -
Wow it works thanks. But is there anything I can use in the adobe suite to convert ac3 to avi or mpeg so I can edit them with most of the editors?
Importing Ac3 with your trick worked the first time. Now it doesnt work anymore. Do you have another solution? Thanks!
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 15:55 -
How to Edit MPEG with VDubMod and save as MPEG?
By DVFun in forum EditingReplies: 11Last Post: 3rd Nov 2009, 15:32 -
Problem with Magix Movie Edit 14 - Sound muted between objects.
By Jo The Veteran in forum EditingReplies: 1Last Post: 3rd Jun 2009, 18:49 -
Looking for software to edit Mpeg-4
By adamch009 in forum EditingReplies: 2Last Post: 11th Sep 2008, 14:22 -
Edit mpeg and burning
By Mange Muck in forum Newbie / General discussionsReplies: 3Last Post: 16th Aug 2007, 15:16
