while opening avi video file in virtual dub im facing ths problem...
if anybody having t solution to overcome ths problem just say the step by step detailed procedure to solve this issue....
You need a vfw xvid codec like koepis xvid, https://www.videohelp.com/tools/XviD_Codec
thanx a lot bro... which codec s required for opening mkv video files....
Whatever codec is used in those MKV files. MKV, like AVI, is a container -- just a "box" that holds video, audio, and other stuff, that may or may not be compressed with any of dozens of codecs. Just to open an MKV file you need a the DirectShow source plugin for VirtualDub and a system installed Directshow MKV reader/splitter like Haali. Then you need the appropriate codecs.
Script redirects to website when opening a downloaded AVI file.
By B Nasty in forum Newbie / General discussionsReplies: 15Last Post: 5th May 2010, 06:01 -
Xvid4PSP .mkv file opening problem
By hibbs in forum Video ConversionReplies: 2Last Post: 23rd Mar 2010, 19:56 -
Opening a file
By ahidayat in forum Newbie / General discussionsReplies: 1Last Post: 2nd Mar 2009, 05:33 -
Problem opening (.avs) file in virtualdub...
By dominator007 in forum DVD RippingReplies: 16Last Post: 19th Nov 2008, 11:53 -
Opening MP4 file
By Schone in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 4th Jun 2007, 21:13
