Error Message:
My project has one title with two buttons and a single clip (just under 25 minutes). I'm not sure why it is having issues now, with the exact same settings it worked with the initial copy. Thanks for any help.Code:DVDStyler v1.8.1 Windows Vista (build 6001, Service Pack 1) FFmpeg: libavformat 52.61.0, libavcodec 52.66.0, libavutil 50.14.0 Prepare Cleaning temporary directory Search for transcoded files in cache Generating menus Generating menu 1 of 1 Prepare Create menu mpeg Multiplexing subtitles (buttons) into mpeg Executing command: spumux -s 0 "C:\MIKETEMPOMG\dvd-tmp\menu1-0.mpg_spumux.xml" DVDAuthor::spumux, version 0.6.14. Build options: gnugetopt iconv freetype Send bugs to <http://www.dvdstyler.de/support.html> WARN: Only one argument expected syntax: spumux [options] script.sub < in.mpg > out.mpg -m <mode> dvd, cvd, or svcd (only the first letter is checked). Default is DVD. -s <stream> number of the substream to insert (default 0) -v <level> verbosity level (default 0) -P enable progress indicator See manpage for config file format. Failed
Do you have the log from this run (when it worked)?with the exact same settings it worked with the initial copy
For me this looks like a 'half' command line:
The syntax should look like:
spumux -s 0 "C:\MIKETEMPOMG\dvd-tmp\menu1-0.mpg_spumux.xml" <
"C:\MIKETEMPOMG\dvd-tmp\menu1-0.mpg" >
"C:\MIKETEMPOMG\dvd-tmp\menu1-1.mpg"GUI for dvdauthor:
https://www.videohelp.com/~gfd/
Help installing DVD Styler
By Garibaldi in forum LinuxReplies: 10Last Post: 3rd Apr 2012, 20:17 -
DVD styler error
By mikeoliver1313 in forum Authoring (DVD)Replies: 18Last Post: 10th Apr 2011, 06:04 -
Burn fails while burning DVD video not data dvd
By cd090580 in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 02:27 -
New dvd styler error.
By mikeoliver1313 in forum Authoring (DVD)Replies: 2Last Post: 21st May 2008, 09:51 -
dvd burn fails in all software authoring programs
By jfrenchu in forum Authoring (DVD)Replies: 8Last Post: 9th Feb 2008, 23:39
