I bought a dvd a month ago,but the subtitle sucks... So,I make a new subtitle..
How can I remove subtitle from vob and add a new subtitle(sub,idx) to vob file.
Thanks~
Open the IFO (not the VOB) in PGCDemux. Demux the video, audio, subtitle and celltime.txt (list of chapters). Convert your IDX/SUB file to SUP using SubtitleCreator. Use Muxman to remux your video, audio, new SUP file, and celltime.txt back to DVD.
Nope, they'll look just the same as the IDX/SUB. To change the font and size you'll have to create new subtitles. You should have done that when creating the IDX/SUB.
So, did it work? You got your new sub in there and it plays OK (don't worry about the colors)?
To get the new VOBs back into the original DVD, getting back the menus and anything else that was there to begin with, open the original DVD (the one with menus) in VobBlanker. Then scroll down to '(Optional) Add back the original menus' at the bottom of Baldrick's Method 2 in his guide:
https://forum.videohelp.com/threads/277950-How-to-add-new-subtitles-to-an-existing-DVD
How to add idx/sub hard subtitles to mkv
By 2ndlife in forum SubtitleReplies: 5Last Post: 29th Dec 2011, 22:22 -
How to add .sub/.idx to avi?
By gOdiSOnyOuRsIDe in forum SubtitleReplies: 2Last Post: 12th Jul 2009, 13:10 -
How to remove hearing impaired subtitles from idx/sub format?
By Talayero in forum SubtitleReplies: 6Last Post: 3rd Sep 2008, 12:40 -
Checked stickies, cant add the idx/sub files to a video
By Kaminoshi in forum SubtitleReplies: 8Last Post: 9th Jul 2008, 13:57 -
How do you add switchable .idx / .sub to dual audio .AVI (XviD)?
By NextJinGamer in forum SubtitleReplies: 4Last Post: 1st Jul 2008, 17:42
