I have an older model (2004-2005) JVC-GRD72U Mini DV Camcorder. My computer will not recognize it, via firewire (or USB) to transfer video.
I have an iMac 24" with Snow Leopard and I also have Windows 7 with BootCamp. I've tried on both OS's with no luck. I've tried to capture with the following, Final Cut Pro, Final Cut Express, iMovie, Windows movie maker, Adobe Premiere Pro.
Nothing seems to work. I can't find drivers to download for this either that would work with Snow Leopard or Windows 7.
What would you recommend to transfer my dv tapes to my computer with my current setup? Should I just do this through a canopus 110 or 300 or should I get a mini dv player and then transfer through the canopus or some other analog to video converter. I assume there will be some loss of video quality going through the canopus since I have to use the s-video instead of just straight fire wire transfer. Sorry if I sound stupid I'm just not sure the best way to go about this.
Thanks in advance for the help!
				Results 1 to 16 of 16
	i'd pick up another dv or hdv cam. and maybe a pc to replace the mac. --
	Sad story.
 My brother showed up with a JVC MiniDV cam and for whatever reason, the Mac and PC didn't work the first time. I struggled and got the PC to work but since this was 4+ years ago, I forget what I did.
 I agree. Try a different computer or better play your tape on a Sony or Canon DV/HDV and capture from them.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	If the Canopus devices (do you have one?) work with your computer, then there's no hardware or software problem since the Canopus devices also output DV - just like a camcorder.
 People are almost giving away DV camcorders on eBay. Certainly cheaper than the Canopus capture boxes.
 Cheers,
 David.
	There is a driver needed for my Camcorder which I do not have nor can find online. OSX and Win 7 may recognize the device is there although I get no indication of this but the video editing softwares I mentioned do not recognize it at all and will not capture with this device. It may be because the video editing softwares are too new.
 I used to capture with the same camcorder but with an older version of adobe premiere pro and windows 2000 and it worked fine. But now with a newer version of windows and premiere pro, no luck.
	If this is a MiniDV camcorder, no additional drivers are needed to capture over Firewire.
 Access to stills over USB does require a camera specific USB driver.
 The camcorder's IEEE-1394 port may be non-functional. Only way to tell is to test it on more computers or other devices with IEEE-1394 inputs such as another camcorder or a DVD recorder.Recommends: Kiva.org - Loans that change lives.
	It must be the video editing software then.
 When I plug it in on the windows 7 side, there is an audible sound that tells me it was plugged in. I don't get any indication on the mac side.
 But still the video editing softwares capture device will not recognize that there is any camcorder plugged in.
 Maybe I should try different video capturing software.
	it could also be a bad firewire cable or port on the computer. --
	Thanks...WinDVworks great!
 ON the mac side though FCE, FCP and imovie do not work at all. I prefer to edit in FCP or express too so it looks like I'll have to capture in windows and transfer to the mac side to edit in Final Cut. A minor pain in the butt but at least I can capture now.
 I even tried FireWireSDK26 on the mac side with no luck
	You'll need Quicktime Pro on the Mac to convert DV-AVI to *.dv or try Enosoft DV processor (free) on PC to make the conversion. The conversion is lossless. Recommends: Kiva.org - Loans that change lives.
  want too capture movies from analog camcorder into computerBy shashgo in forum Capturing and VCRReplies: 3Last Post: 7th May 2012, 07:19
  How to capture real-time video from my camcorder onto my PCBy seanhalley in forum Capturing and VCRReplies: 2Last Post: 2nd Aug 2011, 05:37
  video capture problems - HV20 camcorder is controlled but no video captureBy chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 11:49
  Question about 2nd Hard drive for Video Capture??By VEBouto in forum Capturing and VCRReplies: 8Last Post: 21st Nov 2009, 07:46
  Playing live video from camcorder through computer to digital projectorBy StevieBlunder in forum MacReplies: 6Last Post: 3rd Jun 2008, 12:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
