Hi,
I need some QCIF and CIF sequences in YUV420 format (in particular NEWS and AKIYO) for my research and I am unable to find what I need. I went to this site http://trace.eas.asu.edu/yuv/ and they have a lot of sequences but unfortunately, they do not give information about the sampling rate.
Any leads would be helpful. I am particular about the sampling rate since my work is on temporal concealment and it makes a difference.
Thanks !!
I think some of them are mirrored here
http://media.xiph.org/video/derf/
If you use rawsource in avisynth, it will also give you the frame rate for the .y4m sequences, but I'm not sure how accurate it is. Both Aikyo and News are listed as 29.97 fps
If you read the readme text file, both are listed as 60 for the frequency, and that suggests they are from NTSC 60Hz regions. Therefore, the 29.97 fps might make sense.
http://media.xiph.org/video/derf/sotka.cs.tut.fi/cost/Ossi/sequences/README.sequences
Avisynth: PNG sequences on MP4 video
By KBII in forum SubtitleReplies: 0Last Post: 7th Feb 2012, 04:08 -
A C++ Program to read in YUV frame at QCIF (176x144) resolution
By yoursclark in forum Newbie / General discussionsReplies: 0Last Post: 29th Jul 2010, 03:55 -
Where can i get YUV444 & YUV422 raw Video sequences?
By goldenmean in forum Newbie / General discussionsReplies: 5Last Post: 15th Feb 2010, 12:51 -
Recommended format for conversion to image sequences (particularly from DVD
By richardjc in forum Video ConversionReplies: 6Last Post: 22nd May 2009, 11:53 -
Auto-remove common sequences e.g. credits?
By dez93_2000 in forum EditingReplies: 2Last Post: 24th Oct 2007, 08:02
