Last week the local (45 miles) Fry's store had all at $39.99.
Diamond (ATI) 650 PCIe Internal ... SD NTSC-M and ATSC/QAM tuner, 3D comb filter
Diamond (ATI) 650 USB2 External ... same box copy as PCIe version
Diamond (ATI) 750 PCIe Internal ... single HD ATSC/QAM tuner but GPU hardware acceleration if used with an ATI HD series display card.
Results 61 to 74 of 74
http://www.kiva.org/about -
I checked Fry's online store first and they are currently sold out of the USB version of the Diamond (ATI) 650, but some brick-and-mortar stores still have them. I don't want to be a rumor monger but I think that the TV Wonder 650 line may be nearing the end of production. It seems like fewer US stores have it in stock now that the PCI-e version of the TV Wonder 750 has arrived here.
Fry's usually is the destination for closeouts.
The advantage they have is fewer stores to stock vs. BestBuy and a "who cares" attitude to customer service.
Your advantage there is you know more about the products on sale than the store help. But the Fry's buyers in Corp. know much more than you why those products are there and on sale.Recommends: Kiva.org - Loans that change lives.
Alright, I plan on making a purchase tonight (seeing as I will be able to use my mother's credit card to make another purchase I am going to make) so I want to buy my capture card at the same time as well. I am pretty much settling with the ATI TV Wonder 650 now, but which one am I really better off with ? The PCI or the USB ? My old capture card set up I have a pretty good set up for (I have a usb extendor so I can have the actual card closer to my TV). If I were to go with the USB, should I buy those Wii S-Video cables too ?
The PCI version of the Diamond (ATI) 650 series is the hardest to find of the group. Amazon.com had the best price I could find from a source that I know is reputable http://www.amazon.com/ATI-TV-Wonder-650-Tuner/dp/B00138CJD4/ At least you get free shipping. Maybe you can do better, but double check to make sure the picture shows a PCI interface, since they are not as common as the PCI-e version.
Last week this was $39.99 at Frys Roseville.
Still on sale Fry's online
550 USB2 http://www.frys.com/product/6124759?site=sr:SEARCH:MAIN_RSLT_PG
550 PCIe http://www.frys.com/product/6119069?site=sr:SEARCH:MAIN_RSLT_PGRecommends: Kiva.org - Loans that change lives.
oops, I meant the 650 not 550.
We have a Hauppauge 1850 card.
Does any one have the values for the following parts on this board.
C15,C16,C17,C183,C184 R5,R6,R7
It would be better yet if we could get the circuits for the video inputs of this board . S-Video and C-Video.
We had to remove them because of spilled COKE on it. Yes Coke is like a acid.
The circuit board pads are still good.
any help would be GREAT.
CharlesB -
If I was the first one to it . It would of been cleaned the right way. But some one else though they could do it Hi Hi.
We replaced the resistors with 75 ohm and the caps with 2ufd and it is working . Just need to install the correct size.
The video go'es to the CX23887-15 chip but we have be unable to get the full PDF file that chip.
Thanks CharlesB
Questions about Hauppauge 1196 WinTV HVR-1250 PCI Express Card
By Wizard23 in forum Capturing and VCRReplies: 15Last Post: 25th Feb 2011, 15:22 -
Hauppauge WinTV-HVR-950Q
By mauiwowi in forum Capturing and VCRReplies: 1Last Post: 28th Aug 2009, 21:43 -
MPEG capture software recommendations for WinTV HVR 1850
By justin81 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2009, 09:38 -
WinTV HVR 1800/1850 - interlaced capturing?
By justin81 in forum Capturing and VCRReplies: 1Last Post: 10th Jul 2009, 10:13 -
Hauppauge WinTV HVR-1800 Jerky unless recording
By michaeldg1 in forum DVB / IPTVReplies: 4Last Post: 6th Apr 2009, 15:10
