  1. I am trying to find a way to hack the area code of this DVD.
    (apparently I am the only buyer of this stuff ?!)
    thanks for your help
    My be can I use the same procedure as for the DVP4320 ?
  2. - Turn On unit
    - Open the loading tray
    - Press the Setup button on the remote
    - Navigate to the Preferences page using the Right arrow key
    - Press the Down arrow once to enter the Preference page
    Enter 1, 3, 8, 9, 3 and 1 on the remote
    You will now see the current region code displayed
    - Use the Up/Down arrow keys to select the region required or 0 for all regions
    - Press the Play button on the remote (if this doesn't work then press the Ok button)
    I found this here
  3. Left Column,
    <------DVD Hacks
  4. In fact this procedure works perfectly with the DVP 2320
    - Turn On unit
