I have a Samsung HD, model LN-T4665F. I started having a problem about a year ago with it taking longer for the TV to come on. The red light is on and it clicks and makes the musical sound. It started taking up to 10 min to come on. The last month we never turned it off, we let it go into sleep mode. Some accidently turned it off, now it won't come on at all. It continue to click and make the sound. I can't even turn the TV off with the button on top. Anyone else had this problem?
	I have the same TV but (luckily) haven't seen that problem. Can you get audio out of the TV?
	For lots of things electronic, pulling the plug for a few hours resets them. Probably wont help, but it's all I got other than suggesting you make a call to Samsung to see if they can help.
 Tony
	I unplugged the television overnight and it turned on this morning. Of course I had the pink and green pixels. I cut the TV off twice biut wa unable to get ride of all of them. I decided not to push my luck and left it alone. I am in the process of trying to find out if there is a class action case going on against Samsung since there are numerous complaints about the same problem. If any one knows about a case, please pass it along. Thanks
	is it out of the 1 year warranty period? did you report it as malfunctioning to samsung within the first year? if not you've got no case. just another pile o' junk. --
	Call Samsung and see if they can help or at least quote a fix.
 Cost depends on which module needs replacement. If you can get them to tell you, your local LCD-TV chop shop might get you a module cheaper than Samsung's "flat rate". Consider yourself lucky. Most LCD's inverter fails first. Maybe your problem is a module in stock.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	You could try low power mode in the settings menu,the coloured pixels are usually caused by the power modulator board,its not a fix but could improve the picture quality,till you can get it fixed,ive read in some forum or other the power board can be adjusted,but i wouldnt try it yourself-can be done on LG tv,s anyway
  PC won't start No graphicsBy jollyjohn in forum ComputerReplies: 19Last Post: 27th Jan 2011, 23:20
  Avsp won't startBy vidalien in forum EditingReplies: 12Last Post: 14th Mar 2010, 18:04
  was working now it won't startBy scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 30th Jun 2009, 00:30
  PC won't startBy DuBsTaR in forum ComputerReplies: 8Last Post: 8th Nov 2008, 00:11
  Do Samsung HDTV's have an RF antenna connector for receiving off-air HDTV?By pianopeddler in forum DVB / IPTVReplies: 2Last Post: 6th Aug 2008, 22:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
