I recently got a new Canon hfr10 camcorder and I've shot a video and I'm not sure what preset to use in Adobe Premiere.
The video's size is 1920x1080 and it was shot in 60i.
None of the AVCHD presets in Premiere have 60i. They just say 29.97 fps...
I'm not sure what to use. I'm new to AVCHD.
Results 1 to 21 of 21
What version of premiere ? is it a trial version?
CS4/5 have AVCHD 60i preset . Maybe your install got corrupted? Do you have all updates installed? -
These are the 1080p AVCHD presets I got:
AVCHD 1080p24 Anamorphic
AVCHD 1080p24
AVCHD 1080p25 Anamorphic
AVCHD 1080p25
AVCHD 1080p30
I also have 1080i presets for AVCHD that say 1080i30(60i).....but I want 1080p cause my footage is -
I shot in 60i mode. Its 1920x1080
Which is 1080p right?
I selected the best recording mode in the camcorder (FXP high quality) -
The "p" is for progressive. The "i" is for interlacedWhich is 1080p right?
If you shot 60i, use the 60i preset (ie. dont use the "p" presets.) -
Nope, Premiere can't handle the 24pf streams. It can only handle native progressive streams. The PF24 is 24p in 60i (i.e. not native progressve). You have to inverse telecine it, and Premiere cannot do this .
See this thread
https://forum.videohelp.com/showthread.php?t=321735 -
OK. Now I understand. You guys have been a lot of help. I used the 1080p presets and the footage just didn't run smooth. I just used the 1080i and it looks just like the orginal and runs and looks perfect. Thank you videohelp people!
No, it is 1080i (interlace), not progressive unless you also selected 24p mode (not recommended).
As Jagabo said
"60i" 60 fields per second is the same thing as 59.94 fields per second and is the same thing as
"30i" or 29.97i" interlace frames per second.
All these are marketing speak for what used to be known as 29.97 interlace.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
One last question. What preset do I use in After Effects CS5? There aren't any AVCHD ones. I don't even see a 1080i one either
Just make a custom comp with the same characteristics
Or, you can just drag the footage to the make new comp icon (easier to do) -
The comp will be 29.97 frames per second. If the footage is interlaced , it will have it's fields separated by AE
You can just dynamic link stuff to/from PP -
ok but I still don't know what export setting to select in After Effects
for interlaced footage -
if you want to export interlaced footage, in the render settings select upper field first for field render (instead of off, which is default)
Ok I did that but then the footage came out looking like crap. I don't know how to make the export settings identical to the Premiere export settings I used earlier, which was match sequence settings.
Define crap.... can you be a bit more descriptive ? or post examples ?
Was this 60i footage? or 24p in 60i
What settings did you use? What compression ?
All you have to do is drag the footage on the make new comp button. Add to render queue. Click the hot text for render settings. Field render => upper field first =>ok => render -
Ok I did it again and rendered out an h264 mp4 file with upper field first. And I picked a bitrate of around 20mbps and it turned out good. The one that looked like crap was like squiggly looking. The only thing I changed from that file was the mbps. God this is confusing
60i and ffmpeg or mencoder
By wiz561 in forum Video ConversionReplies: 9Last Post: 9th Jan 2012, 17:02 -
60i to 30p without re-encoding?
By bobthegoat2001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 38Last Post: 30th Sep 2011, 08:55 -
60i container help
By Bengali in forum Video ConversionReplies: 18Last Post: 9th Feb 2010, 07:34 -
Editing in Premiere Pro 1.5 (project preset: widescreen or custom?)
By vid83 in forum EditingReplies: 0Last Post: 27th Dec 2008, 23:53 -
Premiere Pro encoding preset - Can't find it - Pls help!
By slinky005 in forum Video ConversionReplies: 1Last Post: 26th Sep 2008, 13:21
