  1. I have the Acer 6930 running on Windows 7. The webcam/mic was working fine in Vista, ever since I've upgraded to windows 7, the volume on the mic is very low. I've tried reinstall the webcam + audio drivers but those didn't help. I also checked to make sure the volume on it is cranked to the max, if I turn up the microphone boost, there is alot of static. Ideas?
    USA
    W7 handles audio differently than Vista or earlier Windows versions. Unless you can find a W7 driver for your mic, not sure of a easy fix. You might try an external mic and see if that helps. Or start searching the web for your specific laptop and a fix.
  3. The driver is just the webcam driver right. since it's built in to it? They did have a win7 driver but that didn't help. I was thinking that it was a setting somewhere.
    Apr 2004
    Miskatonic U
    Audio drivers will be separate to the webcam driver
    Read my blog here.
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Acer has a support website with all the drivers. Also answer questions online.
    http://support.acer.com/us/en/drivers_download.aspx
    http://www.kiva.org/about
  6. Originally Posted by edDV View Post
    [Attachment 2186 - Click to enlarge]
    Yes edDV, I tried installing the webcam and audio drivers already from there but they didn't work. They told me to reinstall my win7 after I told them what I told you guys here.
  7. No idea guys???
