Alright I'm Having issues Writing DVD's for the PS3, They work on most all other DVD Players but not the PS3
I am Using AVS to Convert from Avi to Mpeg2
I am Authoring with DVDLabPro
And Burning with ImgBurn
I also Tried Authoring/Transcode/Burning with ConvertXtoDVD and no luck
I am using Memmorex DVD+R's
What am I doing wrong is it the Media?
The Australian PS3 happily handles movies created this way. There are two things that jump out as possibilities, beyond the dubious media.
1. The PS3 is resolutely region locked. If, by some minor chance, you have added a region code for the wrong region, it will not play. I don't believe this is the case here, but it is possible.
2. More likely, you have created PAL discs, and the US PS3 is NTSC only. I don't know for certain that the US PS3 is NTSC only - the Australian PS3 plays PAL and NTSC without any problems, and outputs either natively - but most US equipment is still NTSC only.
You can check this by open the VOB files in mediainfo and looking at the resolution and/or framerate. 25 fps or 720 x 576 means PAL.
What, if any, error codes or messages are you getting from the PS3 ?Read my blog here.
Can I use my PS2 controller on my PS3 to play PS3 games?
By jbitakis in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 15:24 -
AVCHD DVD and PS3
By DesossiriboNucleicAcid in forum Authoring (Blu-ray)Replies: 4Last Post: 14th Feb 2010, 15:14 -
DVD to PS3
By Pliny in forum MacReplies: 2Last Post: 20th Aug 2008, 08:32 -
compress ps3 to 1 dvd ?
By pcb in forum Newbie / General discussionsReplies: 2Last Post: 26th May 2008, 12:58 -
PS3 Video 9 - .AVI to PS3 - Settings
By dec60228 in forum Video ConversionReplies: 0Last Post: 22nd Feb 2008, 14:48
