Problem is I load a decrypted file from dvd decrypter, change audio output to lame 192k, set width to 720, size is 1/4cd size, and hit 'start encode'
And there's no prompt screen at all, and on the program itself, on the bottom, it gets stuck when it says "normalizing audio volume...wait...WAIT" or something like that, but nothing is encoding at all, my cpu is as 0% usage.
I have avisynth, lame, ffdshow, .net framework 4.0 all installed, so what gives?
Here's what it says in the log:
16:12:16 0.98.4 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
16:12:16 Selected Input file: E:\DBZ_SEASON02_D1\VIDEO_TS\VTS_02_1.VOB
16:12:16 Selected Output dir: E:\temp\
16:12:16 Selected Final Name: dbz40boi
16:12:16 Selected Container type: MP4
16:12:16 Selected Encoder: DivXH264
16:12:16 Selected Size: 1/4 CD / 1
16:12:16 Selected Profile: 2_Pass_Balanced.xml
16:12:16 Selected Resizer: SimpleResize (neutral soft) / 720
16:12:16 Selected Filters: RemoveGrain(mode=2)
16:12:16 Selected Deinterlacer: AUTO
16:12:16 Selected Field Order: AUTO
16:12:16 NeroAACEnc.exe: not present
16:12:16 Using Matrix:
16:12:16 Track Language 1: 81: AC3 2/0 192
16:12:16 Audio Codec 1: Lame
16:12:16 Audio Quality 1: 192
16:12:16 Audio Channel 1: Stereo
16:12:16 Track Language 2: NONE
16:12:16 Audio Codec 2: Ogg Vorbis
16:12:16 Advanced Audio Settings DUMP Track 1
16:12:16 Nero Option Profiles: AUTO --- Encoding Mode: Quality
16:12:16 CCT Option Profiles: AUTO --- Channel Options: AUTO
16:12:16 Lame Settings: ABR
16:12:16 Audio Normalization: 1
16:12:16 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add:
16:12:16
16:12:17 Dgindex CMD: C:\Program Files (x86)\AutoMKV0984\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=81 -YR=2 -AIF=[E:\DBZ_SEASON02_D1\VIDEO_TS\VTS_02_1.VOB] -OF=[E:\temp\movie] -exit -minimize
16:12:26 D2V file size: 152811 bytes
16:12:26 Audio 1: movie t81 2_0ch 192kbps delay -214ms.ac3
16:12:26 Pre Audio 1' Size: 29862144 bytes
16:12:26 Applying DelayAudio of -214 to audio file: movie t81 2_0ch 192kbps delay -214ms.ac3
Color problem with x264 output + other x264 questions
By serexl in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 18:31 -
MP4 (x264 / AAC / 720x480) to MP4 (x264 / AAC / iPod res)
By GrayStrickland in forum Video ConversionReplies: 2Last Post: 15th Jun 2009, 10:20 -
Automkv problem
By Tripledrop in forum Video ConversionReplies: 5Last Post: 7th Jun 2009, 15:46 -
X264:How do you encode in 2pass ?
By themaster1 in forum Video ConversionReplies: 9Last Post: 25th Apr 2009, 17:29 -
Problem with AutoMKV ( there is no audio! )
By billyww in forum Video ConversionReplies: 11Last Post: 11th Jan 2009, 22:16
