Results 1 to 10 of 10
  1. Member ricardouk's Avatar
    Mar 2005
    Portugal
    Hi everyone
    Just tested out a player ive seen recommended here and despite getting the portable version and selecting splayer not to associate with vide formats...it still did.
    can anyone tell me how to get rid of this references:
    ive changed the default player but im unable to change the references circled in red, i hate when a program does something like this, it reminds me of bad experiences with codec packs in the past...grrrr...
    I love it when a plan comes together!
  2. Always Stay Away from Chicken Shit! coz codec are not codecs but back-doors.
    Stick to to the trusted ones like VLC or whatever you like and prefer.
  3. Member ricardouk's Avatar
    Mar 2005
    Portugal
    i only use MPC HC and sometimes VLC but someone here (a reputable member) recommended it and i tried but won't make the same mistake again, anything that can be done about the "hijack" problem?
    I tried splayer portable and installation version and it didn't take over any associations.
    Did you select yes in the startup where it asked about set as default player?
  5. Member ricardouk's Avatar
    Mar 2005
    Portugal
    no i clicked the manual button and made sure (double and triple checked) no video files where associated with splayer.
    i've asked about this on their blog but i only saw chineses/japanese comments before mine.
  6. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Uninstall the program - have a look in the registry for any remnants of the program and delete those as well.
  7. Member ricardouk's Avatar
    Mar 2005
    Portugal
    its a portable program... cant uninstall it
    Aug 2004
    Have you tried to run the .bat file in the splayer folder?
  9. Member ricardouk's Avatar
    Mar 2005
    Portugal
    i tried running the following bat:
    but it displays several lines with the folowing:
    the system could not find specified value or key in the registry
    Nov 2002
    There is a registry hack that is supposed to prevent persons or programs from changing file type associations (it doesn't work on DivX Plus for some reason)
    HKEY_CLASSES_ROOT\Unknown\shell\openas\command\
    %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1 %2
