Ok, I know this question probably has been asked to death. I apologize a head of time. Here is my dilemma. I have a huge DVD library and I am ripping them to ISO (just the main movie) and them coverting the ISO to a smaller video Format. I am using a external hard drive attached to a Briteview the cinema tube (full 1080 support). I have been trying out mkv format and using the h264 codec and setting the bit rate to around 2500Kbps. wit resolution around 960*580. I have 50 inch lcd HD TV and all in all picture is good, but I am wondering if I can do better. My main goal is to maximize picture quality and minimize file size. I am currently messing around with handbrake and wondershare. Thanks in advance![]()
I wouldn't upresize, convert to max 720x480/576 and then use constant quality encoding.
Stick to native resolutions. For Better quality, go to Blu-ray (Sorry
Also try out all the other alternative encoders, and max out all the quality settings..
https://www.videohelp.com/tools/sections/dvd-to-avi-divx-xvid
Also to get a better response your post should be entitled
best dvd encoding settingsCorned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
New DVD Recorders - Setting 16:9 Flag?
By Plarocks in forum DVD & Blu-ray RecordersReplies: 19Last Post: 17th Dec 2010, 18:33 -
Premiere MPEG for DVD setting
By CircusAim in forum Newbie / General discussionsReplies: 5Last Post: 22nd Feb 2010, 11:23 -
Which is the best video setting on DVD player?
By dzsoul in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Dec 2009, 07:33 -
DVD Shrink setting
By jyeh74 in forum Newbie / General discussionsReplies: 18Last Post: 8th Apr 2009, 09:45 -
Setting up HD DVD authoring station?
By sky81 in forum Authoring (DVD)Replies: 6Last Post: 11th May 2007, 16:39
