  1. After seeing that I could get better quality at lower bitrates and smaller filesize, I have started endoding some of my movies to play on a ZuneHD to H.264. I currently use format factory which takes advantage of mencoder. I was wondering is there any noticeable difference in encoding time when using mencoder vs ffmpeg?
    Both are based on x264 so you should get same quality if using same settings/profiles. Maybe format factory using different x264 quality settings, 2-pass, etc
