I ripped a couple of movies recently and converted them to avi files. Both movies are complete according to my pc, but when I play the DVD on my Magnavox MWD 7006, it gets about 1.5 hrs into the movies and it just stops..like the movies have ended. I have double-checked and both of the movies are complete according to windows and both movies will play until the end on the computer. Any ideas??
If its happening towards the end of the movie it sounds like its possibly bad media. Often the case of bad media is around the edges where the end of the movie would be.
Reburn to a different brand of discs. Try verbatim or go online for ty discs.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thanks, I will try. This happened on 2 different types of disks, but what the heck. You never know.
Remember.."Resistance is futile" -
Media player Classic won't let me "navigate" using mkv files
By FatalX in forum Software PlayingReplies: 0Last Post: 20th Jul 2010, 20:51 -
AVI won't play. VLC say's doesn't support "IV50" Format. All codecs present
By Sikander in forum Software PlayingReplies: 2Last Post: 21st Feb 2010, 07:40 -
.avi file "sticks" on dvd player
By Ogilvy in forum DVD & Blu-ray PlayersReplies: 6Last Post: 3rd Feb 2010, 12:24 -
xvid-AVIs won't play until re-saved in "copy"-mode
By Information in forum Video ConversionReplies: 0Last Post: 5th Dec 2009, 09:03 -
Will my regular DVD player play a "blu-ray to DVD " disc ?
By htp367 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Oct 2008, 12:28
