Hi everyone, first post. (posted to BD Ripping thread as well...)
I have a number of "demo clips" created by backing up with AnyDVD-HD and grabbing a stream with either BD Rebuilder or TS Remux. I am looking to do a simple fade from black at the beginning and fade to black at the end. Every editor I have tried wants to re-encode.
Can this be done any other way? My best solution so far is to cut out the beginning and end 5 seconds, take those two cuts and make each of them a fade in/out, re-encode just those two and reattach them to the original clip, but that is a major pain, and some of these clips will be under "videophile" scrutiny on very large screen displays.
Any other thoughts? I need to keep the multi-channel audio tracks intact as well, along with 24 fps.
Thanks in advance,
Dan
Vegas Pro 8/9 supports smart render for camcorder formats (various DV, HDV, IMX, XDCAM) but not AVCHD (yet) or "Blu-Ray".
Most camcorder formats are CBR. VBR GOPs present special problems especially for audio sync.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Help for adding Fade In/Out and Joining many clips together
By joberrick in forum EditingReplies: 1Last Post: 11th Jul 2011, 21:44 -
Simple fade-in/out of clips created using TS Remux withour re-encode?
By Dan Miller in forum Blu-ray RippingReplies: 1Last Post: 6th Jun 2010, 12:11 -
VirtualDub: Fade between clips effect
By David_UK in forum EditingReplies: 5Last Post: 14th Apr 2009, 15:25 -
Separating 2 Clips joint by fade in effect?
By InSaNiTy in forum EditingReplies: 0Last Post: 3rd Aug 2007, 15:19 -
how can I add "Fade in / Fade out" effect in my video clips
By mb508 in forum EditingReplies: 5Last Post: 9th Jul 2007, 17:02
