Results 1 to 9 of 9
    Aug 2009
    Planet Earth
    Please I want Program cutting MKV But same format and The same quality
    Jun 2004
    California,United States
    Mkvtoolnix can do some chapter splitting but no cutting.
    Tony
  4. Member bat999's Avatar
    Feb 2008
    Hi
    mkvmergeGUI has 'Global' option to Enable splitting... After timecodes
  5. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    If you're just looking to do a simple cut, I think splitMKV (command-line) might work. Haven't tried it myself, though, so I don't know offhand if the resulting MKVs all play properly, or if it just does the same thing a normal file-splitter would do (simply chop the file into chunks of x size).
    Aug 2009
    Planet Earth
    Thank you for all
    How to merge Parts mkv
    Jun 2004
    As Bat999 indicated above with his reference to MKVMerge GUI as part of the MKVToolnix programs is what you would use to reconnect them back up and do what ever re-muxing you need.
    Tony
  8. Member bat999's Avatar
    Feb 2008
    But mkvmergeGUI has 'Global' option to Enable splitting... After timecodes.
    Nov 2002
    If you are trying to edit out parts of the MKV then you can use Virtualdub 1.9.x test20 with external editor but you'll have to re-encode the file. You'll need the newest version of the Directshow Input Driver and Haali Media Splitter.
    x264
    NeroAacEnc
    MP4Box
    Type / Video encoder (change bitrates for higher or lower quality)
    Program / C:\Tools\x264.exe
    Arguements / --preset slower --bitrate 1000 --thread-input --b-pyramid strict --vbv-maxrate 2000 --cqm "jvt" --fps %(fps) --direct temporal --output "video.264" - %(width)x%(height)
    Output file / video.264
    Audio encoder
    Type / Audio Encoder
    Program / C:\Tools\neroAacEnc.exe
    Arguements / -ignorelength -lc -if - -of "%(tempaudiofile)"
    Output file / audio.aac
    Type / Multiplexer
    Program / C:\Program Files\My MP4Box GUI\Tools\MP4Box.exe
    Arguements / -add "video.264" -add "audio.aac" -fps %(fps) "%(outputname)"
    You could use AviDemux as Baldrick mentioned to edit the file and Smart Render to MKV without re-encoding.
