Just curious what common errors can be attributed to a poor VCR and what can be attributed to the VHS tape. Examples would be lines scrolling up and down the picture, jumping picture, stuff like that. One would think that if a store bought VHS played fine in one VCR then a recorded VHS played with errors, like jumping picture, lines, etc. that it would be the tapes problem. Can better VCR's fix these problems? I just dont want to invest in another VCR to get just a slight improvement in picture quality. Cheers!
P.S If this is answered elsewhere in the forum, by all means just link to other posts and I apologize.
Results 1 to 11 of 11
Many of the problems you're talking about are caused by time base errors. A good S-VHS deck with a line time base corrector can clean up much of it. Some tapes will be too far gone for even that though. Especially multi generation copies. Some TBC examples (using a panasonic ES15 DVD recorder as a time base corrector):
https://forum.videohelp.com/threads/319420-Who-uses-a-DVD-recorder-as-a-line-TBC-and-wh...=1#post1983288 -
I found a used ES15 with the ram drive module borken. It doesn't play or record anything.
The seller says the other functions are ok. So the TBC must be working, right?
I'm thinking of buying it. -
Then I'm gonna buy it.
Can't find a standalone TBC to buy here.
So my setup will be LG RC7000B -> Pana ES15 -> ADVC 110.
Let's see how it performs.
Sorry for hijacking the topic. And thanx jagabo. -
The VCR is the weakest link in any VHS conversion chain.
The difference in VCRs make a bigger difference than any other single device.Want my help? Ask here! (not via PM!)
But a good S-VHS deck cost hundreds of dollars compared to tens of dollars for a broken ES15.
Yep.
I would have to pay 6x more to get a AG1970. -
So?
A good car costs a lot more than a skateboard, too.
A VCR is not the same as the ES15.
Jag, I don't know if you're being facetious, or it you really think the ES15 can replace a good VCR.
If it's the latter, I'm really surprised. You've been around long enough to know better.Want my help? Ask here! (not via PM!)
I believe he is not saying that the ES15 would be better than a good S-VHS deck. But, if i can get one cheap (and a good VCR is much more expensive), it's a good deal.
Poor Video Image from PAL VHS Capture
By ww12345 in forum Newbie / General discussionsReplies: 4Last Post: 18th Sep 2011, 12:57 -
Poor man's 5.1
By Haopengyou in forum Media Center PC / MediaCentersReplies: 0Last Post: 18th Nov 2010, 07:53 -
How we can make the best video quality of poor vcr movies and songs.
By nusratjaveid in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2010, 12:01 -
Interlacing artifacts on poor VHS conversion
By binister in forum Video ConversionReplies: 6Last Post: 2nd Jul 2008, 19:05 -
Poor Quality
By Net_Bug in forum Capturing and VCRReplies: 3Last Post: 29th Mar 2008, 16:37
