Hi everybody.
This is my first post and I'd like to share with you an unexpected problem with SANYO VPC-FH1.
I have bought this videocamera and I would like to connect it permanently to an external monitor, but when I try to record anything, the image in the external monitor is cut and only can see what I am recording in the LCD.
In addition, apparently the signal only can be extracted to the external monitor if we select the system NTSC. With PAL we cannot even see the live image in the monitor, only in the LCD of the videocamera.
Briefly:
TV OUTPUT PAL: No output when live image. No output when recording. Only output with playback.
TV OUTPUT NTSC: Output when live image. No output when recording. Output when playback too.
Does anyone knows if this is a firmware problem?
Does anyone knows the e-mail of the SANYO technical support to see if in the future this problem can be solved?
Thanks for reading.
