Thought some of you might be interested in the live feeds from the undersea rovers at the BP leak site in the US. Enterprise ROV 2 has some good video presently. The other ROVs may be be idle, so you have to try the different feeds at times. ROV 2 is setting at the top of the blowout preventer watching the cap that was just installed a couple of days ago over the outlet pipe. And is also leaking because the pipe is so damaged.
They are also pumping heavy drilling mud into the preventer at extreme high pressure to cap the well inside the blowout preventer. You can see when they are pumping the exhaust plume turns brown.
http://www.bp.com/genericarticle.do?categoryId=9033572&contentId=7062605
You will need a plugin to view the live video. FireFox works well and will prompt you on the plugin. IE is a bit harder as you have to install a ActiveX control, then choose a ROV feed and open in a new window. Great video considering it's taken at a depth of over 5000 feet.![]()
If they are able to pump enough heavy mud in there and cap the pressure, then they will force concrete in for a final cap. Maybe in the next few days. ROV 2 moves around at times for different views, so if you watch a while, the video changes.
Results 1 to 1 of 1
Live Video Mixing with Flash Media Live Encoder
By fuggles7 in forum Video Streaming DownloadingReplies: 0Last Post: 7th Apr 2012, 14:08 -
how to replace a head in a video with my own?
By bigtime1957 in forum Newbie / General discussionsReplies: 12Last Post: 11th Nov 2011, 13:34 -
firefox 3.5.1 - does it have a memory leak?
By minidv2dvd in forum ComputerReplies: 9Last Post: 12th Aug 2009, 10:31 -
AviSynth/Virtualdub mixing like oil and water
By Holonet in forum EditingReplies: 11Last Post: 31st Jul 2007, 20:14 -
Video head cleaning & capture
By MTD in forum Newbie / General discussionsReplies: 8Last Post: 9th May 2007, 20:56
