Results 1 to 17 of 17
You could re-encode the video to a smaller size.
You could re-encode the audio to a smaller size.
You could use a DVD+R discs as the capacity of DVD+R is a little larger than the capacity of DVD-R. You could also try to overburn, which might (or might not) allow you to burn the entire thing to one single layer DVD.
You could cut more parts. -
You could use VSO ConvertXtoDVD to author the DVD5 and it will shrink the file rather than cutting the file or converting it to some other format before authoring.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
He probably doesn't want to use convertxtodvd or dvd shrink, because that would make it a regular DVD, and you'd lose HD
If your video is cropped, you would have black borders to make it AVCHD compatible anyway (1920x1080, 1280x720 full frame). So this requires re-encoding anyway. You could use uncropmkv for this , or multiavchd -
I can't find those DVD+R in my city
Converting to dvd is not an option. I want HD and DVD max resolution is 586p. I would have downloaded a dvdrip instead of a 720p x264 version.
I found an option in multiavchd "fit all" that let me re-encode the movie to fit in the dvd5. Right now I'm burning the result to test.
Thanks a lot -
If the mkv has dts audio then you could re-encode just the audio to 640kb ac3 and not have to re-encode the video.
+R or -R is not an issue. Imgburn will happily burn to either. Your problem will be playback if the resolution is not compliant (as has been pointed out). Very few of the "downloadable" files are compliant. Unless the source was exactly 16:9, is has most likely been cropped. While a program like TSMuxer will happily create the structures using non-compliant material, many players will not play them back correctly or at all. The only fix is to put the missing letterbox bars back in and re-encode. MultiAVCHD (which incorporates UncropMKV) can do this, as can AVCHDCoder. It is also worth considering re-encoding the audio down to AC3 640 kbps at the same time in order to get the best video bitrate you can.
Read my blog here.
Thank You for your reply guns1inger...AC3 640? MultiAVCHD used AC3 348...
If you hover over that setting in multiavchd it will show you all the allowable bitrates for the audio that you can manually set,384 is the default and 640 is the maximum.
Thanks for replies.
I just want to know which is better 384 o 640?
the files that I want to convert are apple HD Trailes with AAC Audio...and 2 pass give me better quality to re-encode a video? -
384 is good enough for if the acc is stereo,640 is best for 5.1 audio.
I use 2-pass fast when using MultiAVCHD
Read my blog here.
Burn AVCHD to DVD5 with DTS High Resolution audio?
By nateo200 in forum Authoring (Blu-ray)Replies: 10Last Post: 24th Jun 2012, 06:21 -
Possible tool from jdobbs for blueray to dvd5/9 avchd backup.
By freebird73717 in forum Blu-ray RippingReplies: 12Last Post: 30th Sep 2008, 03:18 -
Simplest and fastest way to compress LPCM audio to fit on DVD5
By kurbads in forum User guidesReplies: 5Last Post: 18th Sep 2008, 04:15 -
fit 3 movies to dvd5
By thecrock in forum Newbie / General discussionsReplies: 9Last Post: 19th Jul 2008, 15:00 -
How do I make this DVD 9 to DVD5 ?
By vidgo11 in forum Newbie / General discussionsReplies: 4Last Post: 28th Jun 2007, 13:06
